2006 F150 Transmission problem? - Ford Truck Enthusiasts Forums
Old 07-23-2011, 01:24 AM
Apollo-11 Apollo-11 is offline
Apollo-11 is starting off with a positive reputation.
I have a 2006 F150 4x4 with the small block V8. It has an automatic transmission with the push-button overdrive button in the end of the shifter. 130,000 miles.
Driving uphill, it has developed a loud clatter. It's not quite a grinding sound and not quite a rattle. I believe it's in the transmission, but I'm not sure.
EDIT: After reading the forums, it appears that this is the IWE Solenoid.
Last edited by Apollo-11; 07-25-2011 at 01:24 PM. Reason: Found answer to question on forum
4R75E transmission overdrive stumbling... 2006FOMOCO Clutch, Transmission, Differential, Axle & Transfer Case 6 11-05-2015 10:58 PM
Resume button doen`t work. whofan 2004 - 2008 F150 7 10-14-2014 05:25 AM
audio jack gjnicholas 2004 - 2008 F150 4 11-02-2011 10:13 AM
2006 F150 4x4 dash problem Enloe11 2004 - 2008 F150 2 10-20-2011 01:50 PM
possible fuel problem emerg. shut off georay 2004 - 2008 F150 5 04-19-2011 11:12 AM
Tags
06, 2006, 46, f150, ford, grinding, issues, problem, problems, slip, slipping, transmision, transmission, transmition, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
