Sway bar bushing, clunk. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-22-2011, 10:46 PM
bkvanbek bkvanbek is offline
bkvanbek is starting off with a positive reputation.
My local dealer, Superior Ford, couldn't find the clunk, and charged me $65 for looking. But I did, it is the right front sway bar bushing.
I have what must be the 1.25" (32mm) sway bar, and the bracket width is also about 1.25". At Rock Auto they don't list the width or it is 1.5" or 1.75". What do I need?
Old 07-23-2011, 03:35 AM
ak-angler's Avatar
ak-angler ak-angler is offline
ak-angler has a good reputation on FTE.ak-angler has a good reputation on FTE.
I don't know what part number you need. When I replaced mine I found it was just as cheap (with shipping) to buy them from the local dealer. And if they were wrong, it would have been a lot less hassle to return them. Turns out they gave me the right parts the first time.
And the next time you need something diagnosed, you should just send me a check for $65 and I'll post the question here and get you an actual answer instead of "we couldn't find anything".
Old 07-23-2011, 06:29 AM
hanklin's Avatar
hanklin hanklin is offline
Ambassador
hanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputation
Quote:
Old 07-23-2011, 07:53 AM
The story is actually worse than that. It was after they had replace $24xx worth of steering stuff due to an accident, that they also didn't find until I pointed out the twisted shaft on the steering box and a broken mount for something else.
But what sway bar bushing do I need?
Old 07-23-2011, 10:16 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I just bought a set of Energy suspension sway bar bushings for my dads 03' and installed them. If you have a 99'-04' SD these bushings will work. You will need a press to remove the stock bushings. Make sure you grease the new urethane bushings well with the supplied grease. I replaced the stock bolts and nuts with standard grade 10.9 metric nuts and bolts however that is optional.
Bought the bushing set from this guy
Energy Suspension Sway Bar-1 1/4" F-Series 99-04 | eBay
2004 F250 Sway Bar Bushing Replacement .: Articles
Install article from a FTE member
Old 07-23-2011, 01:08 PM
I have already replaced the sway bar bushings and end link bushings once, with Energy Suspension. But now I only need the sway bar bushings, and I need to know what works. It does not look like Energy Suspension sells just the sway bar bushings.
Old 07-23-2011, 06:06 PM
dkf's Avatar
dkf dkf is offline
Quote:
Oh ok, didn't know you already replaced the end link bushings. So you just need the center (U-shaped) bushings.
The OE Ford bushings I took off my dads 03' is Part#: 2034-5484-AA and they are 1 3/4" wide with a 1 1/4" ID. The strap that holds the bushing and bar in place is 1 1/4" wide like yours.
Any of the bushings on Rock Autos site that specifies for Front, 4wd, 1.250" bar from Moog or Raybestos should fit. I don't think all the "bracket width" and "bushing width" specs they list are accurate. They supposibly have a good customer service department, maybe give them a call.
Sway Bar Diameter? Lime1GT 1997 - 2003 F150 6 10-05-2016 01:01 AM
Energy Suspension Sway Bar Bushings Jermafenser 1987 - 1996 F150 & Larger F-Series Trucks 1 05-22-2015 05:43 PM
Front bushings BillyBob69 1999 - 2003 7.3L Power Stroke Diesel 17 08-15-2014 09:14 AM
EX 2005 Front Sway Bar Bushings Ben FORD Excursion - King of SUVs 37 01-15-2013 05:28 PM
What size sway bar do I have?? richboss302 1999 to 2016 Super Duty 3 03-16-2010 12:55 PM
Tags
150, 2005, bar, bushing, bushings, clunk, duty, f250, ford, fornt, front, link, super, superduty, sway, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
