Anyone have a 4x4 F-Superduty?
#61
The Mmarmon-harringtons used a Carrero front axle that was a passenger side pumpkin, with a T-case that had a passenger side front drive shaft. Putting it under the stock F-SD springs eliminated any clearance issues. Quigleys used a BW 1356 T-case and a D60 or D70 axle. Quigley put an adapter plate on the T-case in place of the tailshaft housing to mount the park brake. I'd love to find one of those adapters, as well as the Quigley 10-lug hubs for a D60...
#62
#63
#64
The F-superdutys did NOT always have more springs. And More doesn't mean anything either.
Both of my F-superdutys had 5 leaf rear springs and 2 leaf fronts.
A set of springs from a F-superduty I put in my pulling truck were 8 leaf.
It was all on how it was spec'd out
#65
#70
Hi Brad,
No further progress. I don't plow any more, so it's not urgent, and it just hasn't made it to the top of the priority list.
Is the t-case you bought a BW1356? I'd love a pic and some dimensions of the adapter for the brake...
I have a diagrams & rebuild procedures for the brake, if you'd like.
#71
A friend of mine called me asking if I had any interest. HE got the front axle from another guy who got it from a pick-n-pull. Then he went back and got all the tother stuff. Its good that people know I collect these trucks. LOL. Going to look at 2 F-superdutys today.
I'll get pics as soon as I have all the parts
Anyone know I I should get the leaf springs too? The fronts that is. Did they use different ones on the 4wds?
#72
#73
Now back to the thread, sort of... How common are 4x4 F350 chassis cab trucks? Someday I'd like to convert my tow truck to 4x4 and figured if I could get another chassis cab truck I could just swap the bed over. Otherwise I'd have to convert a 2wd frame to 4x4. I know that's been done before. All I'd need is the dually front hub adapters and a parts truck.
#74
I had a truck that a customer wanted the frame from for his wrecked F350. I was not certain if it would work, so I called Ford and they CONFIRMED they are the SAME frame
137" wb is one
161" is another
O and they are both 1/4" the whole way
As for the Central hydraulics, it is a belt driven hydraulic pump. They way the accessory can be used with the truck in neutral, park, what ever. It is really nice, just a lot of hydraulic lines
137" wb is one
161" is another
If I ever convert the tow truck to 4x4 I would also convert from the PTO drive hydraulics to a belt drive. They say you're not supposed to drive with the PTO engaged, but I don't know. Maybe it's a non-issue but I'm thinking I could do a plow and run it off the hydraulics and/or a front hydraulic winch. The rear winch, boom and wheel-lift are all hydraulic PTO driven.
#75
Here's a little tow truck ****. It's from the sales brochure that came with the tow truck I just bought. It states that the F350 frame is 3/16 whereas the F-SD frame is 1/4"
