my god Phy! iv heard of overloaded,but somtimes ya just got to make a few more trips out of it man lol.
Yeah, but the circumstances were such that I ended up with 4-1/2 yards of decomposed granite in it... Luckily I only needed to go about 5 miles, and didn't have to go over 30mph... I was really impressed the F350 did as well as it did, and grateful the hydraulics were able to lift the bed... It was sitting on the stops, and a real squishy ride. These ol' trucks are pretty tough.
for the first 5-6 years of it's life, my 88 pulled a 20,000 lb load almost every day all over the tri state area of ny, nj, and pennsy.
a 17,000 lb komatsu mini excavator, and a 3,000 lb trailer.
any update on the park brake scenario? I have an f350 tow truck but it weighs 10,000lbs empty, so am way over when towing but I dont want to lose the 4x4 OR the park brake, so anything at all?
easier said than done, or are you buying? this is mostly a yard truck not my business truck or I would but the amunt I use it I can't justify the big price tag
I also want a F-Superduty 4wd. I have only seen one in person. It had the factory parking brake behind a BW1356. I read somewhere that the input and output splines are the same on that transfer case. The one I saw had a flat adapter plate between the two. It also had a huge 10 lug front end. I need to see if I can get some pics.
It's not 4x4 yet, haven't had enough time to work on it.
It was just last weekend that I got the wiring & interior back together.
I just ordered the 5.13 gears for the D60 today...
A buddy is a machinist. I'll draw up the adapter for the park brake and he'll make it for me.
I remember reading an article about a guy that took an F-superduty and made it into a 4wd pickup with a regular bed. I think the article was in off road magazine back in the late 90's.
interesting.anything new on this Phy?
Originally Posted by Diesel_Brad
Go buy a 99+ f450 or F550
for the front axle issue,what about just using a front axle from one of those trucks? then have holes drilled for old lug bolt pattern and or adapter to accept older wheels?
or is that even an issue on these size trucks? i shouldn't just assume they changed lug pattern in '99 like they did on the pickups without knowing.
a t-case to go with parking brake just for some crawl gearing would be a big bonus though.
Mine's still not 4x4. I just haven't had the time... I am still going to do it, and I'll take the tailshaft housing off of the T-case, and make an adapter plate for the park brake. That's how Quigley did it, but they had no parts, and couldn't/wouldn't send me a print for it...
