More turbo help
#31
#32
If you need to bring your truck to a mechanic to bump up the timing then you are going to be WAYY over your head trying to do a turbo setup.
I agree with Lew for mods.
If you search you will turn up 1000s of threads on how to make more power in a 302.
6 liter tune up with bumped timing.
Long tube headers.
Full 2.5 dual or 3" single exhaust with a straight through muffler
Good "CAI" with a big open filter.
Taurus, Mark, or windstar electric fans
Under drive pulleys
Long tube headers.
Under drive pulleys
#33
I just hate to see ppl being disappointed after doing all these "upgrades Lite". I've been there and done that. Not with my truck, but with plenty of other cars. I've also seen my friend go through that with his '93 Mustang GT.
- Timing bump
- Ignition upgrades
- K&N filters and the like
- CAI set ups
- headers
I hear and read a lot of ppl swearing by these things and they might be right. However, my real world experience and that of close friends who have done those things have proven that you're better off saving your $$ for other things.
#34
^^ X2 on that^^
- Timing bump
- Ignition upgrades
- CAI set ups
- headers
#35
no i can do the bump its just i don't have any place to put my truck so i can work on it, im at an apartment complex and its really hard to do any thing work wise to the truck here, if i had a friend with a big enough garage/driveway id be taking it there but i don't know many people in Louisville...
#36
I wont go into explanations about my experience with other cars of my own, but *my* personal experience has proven *to me* that those things are worthless for the $$ spent unless there were problems with the ignition or the exhaust or the air filter were blocked in some way. In that case repairs would be needed anyway and they could be done with OEM parts and specs with excellent results.
Of course, your mileage might vary, yadda yadda...
#37
#39
Just to prove to yourself that you've done some significant improvement, I suggest you go to your local dyno and get a baseline dyno sheet. It's the only sure way you can measure any improvements or lack thereof. You cannot trust your butt dyno. If you can't afford the $$ for the dyno, at least go to the drag strip and get a few runs and save the time slips. It's not as accurate as the dyno sheet, but it will give you some way to calculate HP before and after.
#41
When you go into the motor with heads, cams, stroker kits and other internal mods, you can really begin to see big improvements. Also, that's when these "mods lite" begin to make a difference.
Also, you can see big gains with turbos or superchargers or nitrous oxide shots. But even then, you really need a dyno to quantify your gains (or losses).
I would live to see some actual dyno sheets from real people, (not the manufacturers of after market parts) showing the HP or Tq gains from things like bumps, K&Ns and such. Even headers make relatively little difference without other significant internal changes. Until I see good solid dynocharts showing me numbers, I will not believe the claims of power gains from the bumps, K&N, CAI, headers, ignition upgrades, etc.
Peace out.
#43
Jaime-I just checked to see what ring/gear you have....And my decoder gives it to be either a 3.25 or a 3.31 either one...Check your axle tag, it'll tell it in plain numbers....IIRC, your door tag said it was a Code 17....
But even at that, those are both highway gears...A simple gear swap to a 3.55/3.73 will put the power where you need it...And you'll feel a sizable difference....
And as Bladez and I have said, a set of headers, a timing bump, a cam, etc....Those are simply marginal things, they have a limit, and they tend meet it quicly in terms of how much hp they actually give you....
The simplest, most effective things I'd recommend is a timing bump, a new cam, either port and polish the E7 heads you have, or find some GT40 heads(Stray away from the GT40-P heads...They have a weird sparkplug angle, etc...) or a nice set of aftermarket heads.....
The header will then be a cherry on top....And well, if you get the cam/heads issue worked out, the headers will then more or less be mandatory, as you have then changed the amount of air, etc you can flow.....
#44
Oh yeah, way back in the dawn of time, I remember people using split manifolds in the old Chevy I6s. Offenhauser engines had them as well and they ran dual carb setups as well. For more years than I care to count, the Offys were "the" engine to beat for racing... Maybe some of those old techniques can be applied to the 300 ci, I6...?
#45
Yup...EFI Exhaust manifolds are a cheap upgrade for carbed engine....And Headman makes a set of atual headers....Summit sells them for $189 a pop......
And you're right...Better breathing engines run better all around...And a 300 responds pretty well to headwork; Seeing how asthmatic they are....
Also...Yeah, cams are a given for uprgrades....
