Aeroforce Gauge Question
As I understand the ScanGuage should be accurate as it is interpreting the electrical value from the PCM as seen by the temp sender in the pan, and the MAP sensor. If both sensors are operating correctly then it will be accurate, if they are not they are still accurate as to what the PCM is seeing. Which is why some like analog gauges as a supplement, do you have AE? You could compare the values against it to see if there is an issue with the gauge or if you have other issues.
Alot of the research I did looking for temp comparisons, was you should be around 70-80 degrees over ambient, Mark K stated that the trans is fine all day long at 220F but no more than 30 minutes at 250F, besides, my first cooler is the OTW cooler so I don't see how it could cool that much in 2 more coolers when it is within hot coolant? Maybe I'm wrong and my trans will blow tonight on my drive home, least I'm only 1.5 hours from BTS, but my temps at night(been getting down around 80!) my trans stays 145ish.
on
I may add that trans temps will be higher as read by the Scangauge as compared to a gauge with sender in the test port due to the different locations of the sensor/sender. The TFT sensor is in the Shift Solenoid VB and mine reads 15-20* higher, but still stays below 180* empty at 100* ambient.
I put this together when I put my gauge in. May help you out figuring out some of the functions.
‪Aeroforce.mp4‬‏ - YouTube
Here is with the Fuel and Oil Pressure senders hooked up.
http://www.youtube.com/watch?v=YQsYGH9eAls
