Aeroforce Gauge Question
Here is with the Fuel and Oil Pressure senders hooked up.
Aeroforce Scangauge Fuel & Oil Pressure - YouTube
When I installed mine yesterday I put in the slope and intercept in that was on the instructions and my ScanGauge reads 100 PSI more than my actual fuel pressure.
My boost pressure sensor also reads the exact same thing my fuel PSI gauge is reading.
I know this is an old thread, but what Slope and Intercept did you put in for the Fuel PSI sender?
Yea, it have it set up in the Analog port. I set the slope to 1 and the intercept to 0, this shows my voltage reading from the sensor, and I am getting 4.5-4.9v from the sensors.
I finally got a response from Aeroforce, they think my sensors are bad. Hopefully they will send me out some new sensors ASAP. Depending on how they react with the bad sensors will depend if I send the gauges back and go back to normal gauges.
I checked the setup of mine. I used 37.5 for the slope and -18.7 for the intercept. That is the requirements for the 150 PSI fuel/oil senders.
Here are the instructions for it: Aeroforce Fuel/Oil Pressure Sender
Here is the instructions for the boost sensor : Looks like the same slope and intercept should be used. 100 PSI Boost Sensor
It isn't how ofter you have to, it is how you get a hold of them. If you have a problem (like I did on my install), you have to email them. They will get back to you in 1-2 days, maybe longer. They wont call you or give you a number to call them. Their install instructions suck.
#30
ya i would agree that they suck on that part
ya thats the kit i was looking at the 3 in 1 package kit on there site it like right at $200 and on amazon its at $160 but idk how smart that is or how well they actualy read info or what all it comes with
