egr valve
the upper half is all the electronics for the valve liquid and electronics dont mix
I just hung mine in a cup of purple power cleaner worked great
The inside of your intake manafold looks similair to the egr valve that you are cleaning
heres a shot at mine before I cleaned it ONLY clean the lower half shown here
I also had a bad thermistate I contributed to the gooy stuff
my round egr cooler was good
Do NOT use brake cleaner. Ford has specific instructions about it destroying the EGR valve. Use Carb cleaner or set it upright in a small container of purple power. You don't want any liquid getting inside the valve.
I may have got some cleaning solution on the upper part of the egr valve, is it a good idea just to go ahead and leave it uplugged. I had it uplugged all day yesterday prior to me pulling it off for cleaning and didnt notice any negative affects on my truck, the CEL never came on and ran fine all day unplugged? What are your thoughts on this?
If the EGR valve has problems, you will most likely notice (and get codes). Just be aware, that a poorly functioning EGR system can cause a lot of soot generation, which can cause issues in the turbo eventually. It is well worth it to maintain the health of ALL your combustion system. Little issues can "domino" into bigger ones.
One reason I keep the EGR system is because it tells a LOT about combustion efficiency. Pull it routinely (6 mos or annually) and see if the soot is dry powder that comes off easily, or if there is oilly sludge or tarry material.
