Esof? No power to dash switch 2003 f350 diesel
That is the diagram for the wiring. Also let me post the fuse info for you.
Guess I'll have to split this upload.
Sean <BR>
6.0L Tech Folder
It might but I can't say 100% because that info came from the 03~04 book.
I am not sure if my info covers that far back but I;ll look later tonight.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Well bad news I don't have any data for older than the 2003 year.
I thought I had gotten that older DVD for my set but guess that I didn't.
You might ask in the forun for the year and type engine for your truck.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Have a look at the PDf's in post # 16,18 & 19
That should cover all the diagrams for your model year.
First thing to check is all the fuses that related to the system.
You will likely have to test each wire to make sure that it is
not broken at some point. I will see if I have the pinpoint test
steps. I attached some files to this that I have posted before
and the transfer case one just for interest because it happened
to be with all the others when I uploaded them.
Read the diagnostics PDF and post what you find or if you
have other questions once you start the testing steps.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
#28
#29
#30
