Windows not working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Windows not working
Old 07-21-2011, 01:27 PM
paintballpro650's Avatar
paintballpro650 paintballpro650 is offline
paintballpro650 is starting off with a positive reputation.
Windows not working
I have a 2006 F-250 crew cab. The other day my passenger side rear window stopped working. It will struggle to go down and get hung up after moving less than 1 inch. Then it will not go back up unless you wait a little then it will operate normally. If you try to hold the switch down as it struggles then all four windows. All of the actions are fairly sporadic. Often times the switch on the rear door will work when the master switch will not. I purchased a new master switch and that did not solve the problem. I have tested the relay and fuse associated with the windows and I do not suspect a bad window motor because when everything is behaving all four windows go up and down at a normal speed. If you can shed any light on the situation I would appreciate it. With that having been said I have a brand new Ford master window switch that the dealership will not let me return because it is an electrical part. If anyone can put it to good use shoot me an email.
Thanks!
Power window issue teamlx88 1997-2006 Expedition & Navigator 4 02-02-2014 03:34 PM
Help!! Weird window switch problem - 2000Excursion MNExcursion Excursion - King of SUVs 7 12-18-2013 09:07 AM
Interior Ground - Windows/seats issue '87 me_iam 1987 - 1996 F150 & Larger F-Series Trucks 0 08-15-2011 09:43 PM
Drivers Power Window not working jdguest Explorer, Sport Trac, Mountaineer & Aviator 5 01-19-2011 05:39 PM
1997 Explorer Power Window problem gdennis51 Explorer, Sport Trac, Mountaineer & Aviator 3 05-22-2009 02:11 PM
Tags
89, bronco, ford, ranger, stopped, struggle, window, windows, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
