Worth buying or not? 86 F-250 Diesel
Hey guys,
I would like some advise quick! I have the opportunity to buy a 1986 F-250 4x4 long box, extended cab. It looks like a fairly decent truck, but it has its issues. He would like to know by tomorrow. If I don't want it, hes got a couple other people interested.
The Bad...
Transmission needs work. It tries to go forwards in ever gear. Even reverse and park until it locks in. It doesn't go anywhere in reverse, but you can tell it tries to lurch forward.
Drivers side floor board/body mount has rotted away. The body has sagged a bit on the drivers side, but it looks as if it could be straightened out and look 1/2 way decent again.
Leaks fuel out of one of the gas lines. Not too worried about that, simple fix.
Found some wetness around what I assume to be fuel injectors.
Brakes go almost to the floor before doing any braking.
The engine runs, however it is pretty hard to start and sounds as if it may have an exhaust manifold leak.
The Good...
Its only $1000, or the guy will take a beater mustang I have for it.
Visible areas of the body look good.
It does run.
It has what I think is a 4" suspension lift, and a 3" body lift.
I would be buying it from a friend. He usually has access to parts, tires, people who know about these trucks etc, and may be willing to help me out at least tracking down cheap replacement parts, and possibly help work on it.
I have always wanted one of these, but I'm almost afraid this will be more of a project than I want. I don't necessarily need it to be show quality, but I want it to look fairly decent, be reliable, play around off road, and be reliable enough to handle a Michigan winter. I have worked on my fair share of cars so the mechanical issues aren't over my head, I just don't want to be working on this thing forever or sink a bunch of cash into it.
What do you guys think? Would you buy it? Sorry for the long post, wanted to give you guys as much info as I could.
The Bad...
The Good...
It does run.
Based on everything you've said, I would move on, as much as it pains me to say it. I have always wanted that truck as well. A decent amount of those are easily enough fixed, but others are going to start really digging into your fun fund. A diesel isn't the best option for wheeling because of weight, and starting it in the Michigan winter is going to be a bear when it's running good, let alone as it sits. Still your call either way though.
Yeah I think you guys are right. It would be a nice truck to have, but it more than likely take too much time/money to make it a good solid running truck again. Guess I'll just have to start keeping an eye on craigs list and wait for something in a little better shape to pop up.
Thanks for your input!
The trans issue is likely an internal problem. May be an easy fix by just dropping the pan, or it could turn into dropping the entire trans for a complete rebuild.
The wetness around the injectors is pretty common, and is likely causing the hard starting issues. There are small return lines that can leak, when this happens, air can enter the fuel system and it can be a bugger to get it started.
The brakes could be a minor issue that's simple to fix, or they could be completely worn out, needing major money invested.
The diesel engine and auto trans used in these are both rather stout and reliable units, needing only occasional attention to give 300K or more useable life service. Trans isn't too expensive to get rebuilt ($600-1000), but the engine can be ($4000+).
That's kinda what I was thinking. If he's just going to scrap it, I may offer him 600 today and see what he says.
The floor pan on the drivers side is about gone. I was thinking I just may get away with some fairly thin plate steel, find a couple solid areas yet to weld to on the body, and be able to make a new body mount from there. It would be some work, but if I can get it for 5-600, might be worth it now.
And here is a link to the Photobucket album I have for this truck. These are pictures of my friends pictures from my phone. They are not the best pics, but they will give you an idea of what it looks like now.
1986 Ford F250 Pics
1986 Ford F250 Pics
I'll be honest, that truck looks like it is in pretty decent shape, but looks can be deceiving. Looking at it doesn't help me help you AT ALL!! At least not if you are looking for someone to talk you out of it, haha. The truck just looks mean, and I like it. FOCUS, FOCUS....the issues still seem tough to deal with, but if he is willing to give it up fairly cheap, I would give a go at it.
I think i'll try to see of he will let it go for 600. He has a guy coming to look at it tomorrow so we'll see how that turns out. As long as no hard parts are broke in the transmission, rebuild kits are around 200. I have enough scrap steel to probably make the body straight(ish) again. Go through the injectors and a few other things. I might be able to have it up and running for 1000-1500 including the cost of the truck
