Problem Removing Fuel Filter - Page 2 - Ford Truck Enthusiasts Forums
Old 07-21-2011, 01:11 PM
LSO1123 LSO1123 is offline
LSO1123 is gaining momentum as a positive member of FTE.
Well I got the filter off and emptied it in a bowl. Look at the crap that was in the filter! I'm suprised the truck was even running! I just wonder if it has ever been changed before!
Old 07-21-2011, 01:26 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is gaining momentum as a positive member of FTE.
Actually, that looks pretty goode. No water. The large stuff you can see is not what plugs your filter, it's the very fine particles that plug it up.
Old 07-21-2011, 02:58 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
agreed. that is clean. i have pulled filters off the mack trucks that pour out pure black after 5,000 miles.
Old 07-21-2011, 03:53 PM
Well that's good news! That was the first time I've ever changed a fuel filter so I didn't expect to see stuff like that in there. Now I have another concern. I got the new filter on and got the truck started pretty easily. Checked the filter for leaks and there are none. However, it looks like there is fuel leaking from around the top of the front injectors on each side of the engine but just those two! I never noticed it doing that before I changed the filter. I guess it's fuel, don't know what else it could be. What could be causing this?
Old 07-21-2011, 03:59 PM
Coalroller's Avatar
Coalroller Coalroller is offline
Coalroller is starting off with a positive reputation.
whats the info on your truck? year milage that kinda stuff? If they are all original it might be the o-rings in the return caps that have gone bad and are leaking, or it is pushin out from where the return line are clamped on
Old 07-21-2011, 04:17 PM
Looks like you disturbed the return lines. Like Coalroller said, there are two ORings under the plastic caps that get hard and need to be replaced. The size is 111. Just make sure they are viton to resist the new fuels.
#9464K24 from:
McMaster-Carr
Old 07-21-2011, 04:19 PM
It's a 1993 IDI non turbo. It only has around 90K miles, not sure exactly cause the original odometer stopped working. It sat without even being started from 2007-2009 and has been driven very, very little since then. I seriously doubt that the injectors have ever been replaced. It looks like it's coming out down where the o-rings would be, I don't think it's pushing out from the return lines.
Old 07-21-2011, 04:23 PM
Now that I think about it, you're probably right. While I was fighting with the filter I probably did disturb the return line that's closest to the filter and I took the breather off of the intake and laid it on the other side which probably disturbed that line.
Old 07-21-2011, 06:54 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is online now
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
Amazon.com: Delphi 7135-276 Injector Installation Kit: Automotive
thats a dang good kit right there.
good grade fuel line with it.
i went through two of those cheaper kits from Pensacola diesel,and always had leaks.non so far with this one.
sure is nice not to be chasing fuel leaks all the time anymore.
(i did use Viton O-rings instead again though.)
Old 07-21-2011, 06:58 PM
i ain't rite
Old 07-21-2011, 07:28 PM
Coalroller's Avatar
also you could pm typefour and see how much there are through him ... sounds like yes you probably disturbed your lines and the o-rings were probably dry rotted especially since it wasnt even started for 2 years
HELLO TWISTR New Member Introductions 4 07-01-2016 07:45 AM
cant get my damn fuel lines off my fuel filter housing jetedwards 6.0L Power Stroke Diesel 4 10-14-2014 10:00 PM
fuel line disconnect tool size powerstroker100 1987 - 1996 F150 & Larger F-Series Trucks 6 03-07-2014 03:16 PM
twisted the return fuel line on secondary fuel filter highteckredneck 6.0L Power Stroke Diesel 9 04-23-2012 01:04 PM
Fuel Filter Wont Come off caleb6.9 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 08-24-2009 05:44 PM
Tags
2006, 69, 73, change, diesel, excursion, f150, filter, flex, ford, fuel, idi, problems, remove, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
