2002 F250 7.3 d Brake Problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-20-2011, 07:11 PM
firstgrasshopper firstgrasshopper is offline
firstgrasshopper is starting off with a positive reputation.
Please help, my brakes stop the truck good but not like new, when the truck comes to a stop the pedal then starts to fade on to the floor the truck will creep off if you dont press the pedal on down. Have replaced the pads ft & rr, replaced ft rotors and calipers, also the mastercylinder and hydroboost, still have the same problem. Also replaced the mastercylinder again still same problem, please help.
Old 07-20-2011, 08:28 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
I take it there is no fluid loss?
Are the brakes bleed good? Are they firm or squishy when you push on the peddle?
Most of the time a fading peddle is from a bad master but if you are on the third one that should be ruled out. The last thing to check is the rod adjustment from the peddle to the master, try adjusting the rod a couple turns both ways and see if it gets better either way.
Old 07-23-2011, 09:15 AM
dagren99 dagren99 is offline
dagren99 is gaining momentum as a positive member of FTE.dagren99 is gaining momentum as a positive member of FTE.
Just a shot in the dark - the 7.3's use the PS pump for boost - how's your PS pump? (fluid level & does the truck steer ok)
Old 07-24-2011, 07:25 PM
bad brakes
Hey guys thx for your help. I have bleed the brakes twice no air at all pedal is firm and brakes will thro un in the dash, but when it stops and u sit there for a few secs then the pedal starts to fall on to the floor but it will stop about 2" from floor.
Old 07-24-2011, 07:26 PM
Brand new PS pump all is fine there
Old 07-24-2011, 09:36 PM
Pili's Avatar
Pili Pili is offline
Pili is starting off with a positive reputation.
From what your describing there must be a leak in the system. Its holding pressure just long enough for it to find a weak spot and then it bleeds off the pressure. Did you check all the rubber lines and all fittings though the system? Ive had a problem similar, one of the hard lines was pinched between the frame and the tank. There was a pin hole just big enough to keep the brakes from working.
Old 07-24-2011, 11:05 PM
akaFrankCastle's Avatar
akaFrankCastle akaFrankCastle is offline
akaFrankCastle is gaining momentum as a positive member of FTE.
Hope this helps.
Old 07-27-2011, 07:28 AM
Hey thanks so much for your post especially the instructions. Also I have not lost any fluid at all, do yall think it would possible that one of thr new calipers or one of the two olds rr could have a semi seized piston.
Old 07-27-2011, 07:41 AM
A siezed piston shouldn't cause the pedal to drop to the floor - should be opposite & make it firmer. Could have a leaky caliper or brake line. Check over the lines going to the rear carefully - they have a tendency to rust and "weap" fluid which can cause the symptoms you're describing. I'd follow them from the master cyl all the way to the calipers. Look for damp spots all the way.
Old 07-27-2011, 07:53 AM
Pili's Avatar
did you bench bleed the master before you installed it?
Old 07-30-2011, 09:21 AM
brakes
yes I bled the mastercylinder before installing and bled the brake system till all fluid came out clear and no air , I have a bleeder for that. Will check the lines, but I have not lost any fluid out of the system none what so ever. I was thinkn that if one of the pistons in one caliper was semiseized it would be hard when I 1st pressed the pedal and then if the piston started moving slowly outward then the pedal would start fading toward the floor. System has no leaks.
Old 07-30-2011, 09:51 AM
Snowseeker's Avatar
So you are using a power bleeder? What style? Those power bleeders don't "work" the air bubbles out all the time. Nothing beats a buddy pumping the peddle while you go around and break bleeders loose.
Old 07-30-2011, 10:14 AM
Pili's Avatar
With a semi seized piston you would still have a firm pedal all the way to the floor. With all the new parts you've put on did you flush all the old fluid? Brake fluid breaks down over time due to it absorbing water and although its a slim chance that could be the problem. The brakes are a sealed hydraulic system for the brakes to be soft or the pedal to fade there is either air in the line or a fluid leak. If the master, calipers, lines and fittings are fine then its the booster. There is nothing else it could be
Rear drum brakes, bad wheel cylinder? help Mdc9966 1973 - 1979 F-100 & Larger F-Series Trucks 14 01-19-2017 10:13 AM
Brake line pluming and bleeding Hobdy 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 09-26-2016 02:45 PM
brake problems GubNi 1994.5 - 1997 7.3L Power Stroke Diesel 25 10-31-2009 07:33 PM
unusual brake problem... SEDUCED Brakes, Steering, Suspension, Tires, & Wheels 3 09-09-2005 10:35 AM
spongy brakes/brakes hanging on Blaine Schulte Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 09-19-2003 11:25 AM
Tags
2002, 2003, 96, bleeding, brake, brakes, f250, ford, hard, peddle, problem, problems, prpblems, pulling, seized, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
