Truck died on freeway
Well, start with the suggestions Subford mentioned. could save you $65+ labor an hour. And even if you take it to the $tealership, they may not even have the Technical Know-how if they just have young-guys turning wrenches for them. I've heard of some $tealerships not even knowing about Recall on older Fords with dual fual tanks and had no idea what i was talking about. Remember, it's your Coin to drop.
Profile Ignition Pickup (PIP): Provides crankshaft or camshaft position information for ignition synchronization.
It is located on the stator assembly inside the distributor.
As I said above:
But make sure the small push-on wire at the starter relay on the fender is not hot when you turn the key to the start position before changing the Ignition Switch.
If the power relay clicks on when you turn the key to the start and run positions then the Ignition switch is OK also.
As I said above:
Bad Fender-mounted Relay, corroded/open wiring comes to mind. Be sure to check all the wiring leading to/from the relay and also to the solenoid on the Starter. If any "Green" is evident, get that stripped back to good copper wire and go from there.
Also, have you performed the Self-Test mention on Page 1? This could save you countless dollar$$$$. If everything mentioned has a "PASS", then as SubFord mentioned, PIP may be the culprit. A Remaned Motorcraft distributor is about $90. It's just about $25-$30 more for 1 hour of labor @ your nearest shop.
I am just looking at the parts on OReilly's. BWD ME58 - Distributor Stator Assembly | O'Reilly Auto Parts is this correct? They give a nice military discount so I usually go there.
Yes that is the right part but the distributor has to be removed and tore all the way down to replace it. Most of the time you will need some kind of press to replace it.
Also you will need to time the engine with a timing light with the SPOUT shorting bar removed after you put the distributor back in.
#28
About 75% of the time a rebuilt distributor from an auto part store comes with a bad PIP sensor in them. They seem to test the PIP sensor and if it tests good they do not replace it.
The problem is most of the distributors sent in are sent in for a bad PIP sensor that fails after about 20 miles of driving so of course the PIP sensor passes their tests.
#30
When you get nickled and dimed to death it gets frustrating but when it's fixed, you'll have a great ride you can be proud of. Hang in there!
