Steering Squeak
Steering Squeak
Hello everybody. My 1979 F150 Two Wheel Drive squeaks when I turn the wheel. It is not the power steering, I know that sound. I replaced the driver side inner/outer tie rods and it persists. I greased every zerg I could find, but there is one which will not accept any grease. Driver side front, back of the wheel assembly, towards the front of the truck, looks like it might be kingpin, runs right through the end of the IBeam, but I am not real familiar with the parts. I don't know if that dried up, won't accept grease, and now squeaks, or if it is something else. Does that seem likely? Also, I was told that if the kingpin is what's squeaking and needs to be replaced, it would require shop machinery, a press of some kind. Advice? Thank you.
Thank you Silver. Managed to get a bit of grease into the kingpin bushings, top and bottom. Local repair shop mechanic did a once over and thought it might be the brakes shifting around a hair, or maybe that there is a fitting that needs grease near the top of the pitman arm. Will have to inspect it a bit closer.
