Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 07-20-2011, 12:39 PM
blackford4x4 blackford4x4 is offline
Garage is empty, add now
blackford4x4 is starting off with a positive reputation.
fyi recall info
DETROIT (AP) - Ford Motor Co. is recalling more than 20,000 pickup trucks and SUVs because a defective switch can cause the turn signal, tail lights and brake lights to fail.
The National Highway Traffic Safety Administration said Wednesday on its website that the recall affects certain 2004 through 2011 Ranger pickups, 2002 through 2005 Excursion SUVs, and 2002 through 2007 F-250, 350, 450 and 550 trucks.
About 20,450 trucks in the U.S. are affected, plus Ford is recalling more than 6,000 of the switches that were sent to dealers as replacement parts.
Ford says it knows of no accidents or injuries caused by the problem.
The company will notify owners and dealers will replace the switches free of charge.
__________________
Black 2005 Excursion Limited
6.0 4x4
  #2 (permalink)
Old 07-20-2011, 01:20 PM
Bigpapa346 Bigpapa346 is offline
Bigpapa346 is starting off with a positive reputation.
Thanks for the heads up bu I do not see it anywhere under the search.. Got a link?
  #3 (permalink)
Old 07-20-2011, 02:32 PM
VaSheriff VaSheriff is online now
VaSheriff is a splendid one to beholdVaSheriff is a splendid one to beholdVaSheriff is a splendid one to beholdVaSheriff is a splendid one to beholdVaSheriff is a splendid one to beholdVaSheriff is a splendid one to beholdVaSheriff is a splendid one to behold
Vehicle Make / Model:
Model Year(s):
FORD / E-250
2002-2007
FORD / E-350
2002-2007
FORD / E-450
2002-2007
FORD / E550
2002-2007
FORD / EXCURSION
2002-2005
FORD / RANGER
2004-2011
  • NHTSA Campaign ID Number:
    11V352000
  • Summary:
    FORD IS RECALLING CERTAIN MODEL YEAR 2011 RANGER TRUCKS BUILT FROM JANUARY 25, 2011, THROUGH APRIL 25, 2011 AT THE TWIN CITIES ASSEMBLY PLANT, AND SERVICE PARTS DISTRIBUTED TO DEALERS FOR CERTAIN 2004 THROUGH 2011 MODEL YEAR RANGER TRUCKS, 2002 THROUGH 2005 MODEL YEAR EXCURSION VEHICLES, AND 2002 THROUGH 2007 MODEL YEAR F-250, F-350, F-450, AND F-550 TRUCKS FOR FAILING TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THE MULTI-FUNCTION SWITCH WAS SHIPPED WITH A SUBCOMPONENT (SLIDER) THAT MAY EXPERIENCE DEFORMATION. A MULTI-FUNCTION SWITCH WITH A DEFORMED SLIDER MAY MALFUNCTION CAUSING THE TURN SIGNAL, TAIL LIGHTS, HAZARD WARNING SIGNAL FLASHERS AND/OR BRAKE LIGHTS NOT TO ACTIVATE.
  • Consequence:
    NON-FUNCTIONING LIGHTS COULD INCREASE THE RISK OF A CRASH.
  • Remedy:
    DEALERS WILL REPLACE THE SWITCHES FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT AUGUST 15, 2011. OWNERS MAY CONTACT FORD MOTOR COMPANY CUSTOMER RELATIONSHIP CENTER AT 1-866-436-7332.
  • Notes:
    FORD'S SAFETY RECALL NO. 11C18. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
__________________
SQUIRRELS -- nature's little speedbumps!
  #4 (permalink)
Old 07-20-2011, 04:32 PM
Thanks Sheriff..
  #5 (permalink)
Old 07-20-2011, 05:35 PM
lol mine was not nearly as detailed just in the local news web page Ford recalling more than 20,000 vehicles - KLTV 7 News Tyler, Longview, Jacksonville |
__________________
6.0 4x4
  #6 (permalink)
Old 07-20-2011, 11:42 PM
vrinner's Avatar
vrinner vrinner is offline
2003 Ford Excursion
My Garage
vrinner is starting off with a positive reputation.
+1 for Ford on being proactive on this.
__________________
'02 F350 DRW Crew 7.3 PSD long bed. "The Tow Pig"
'03 Excursion Limited 7.3 PSD 4X4. "The USS Alabama"
'84 Mustang SVO - Ex Daily Driver. 140K+ Miles. Near stock.
'86 Mustang SVO - The Race Car. Maximum Motorsport full tilt boogie.
'86 Mustang SVO - Dynoed at 450 RWHP currently running 380+ RWHP.
'86 Mustang SVO - The Ruststang. "I like my Fords and I like 'em with Turbos!"
  #7 (permalink)
Old 07-21-2011, 07:30 AM
Excurvelle's Avatar
Excurvelle Excurvelle is offline
Excurvelle has a good reputation on FTE.Excurvelle has a good reputation on FTE.
20,000 is not a lot of vehicles
__________________
2005 Excursion Limited 2WD 6.0L all stock
  #8 (permalink)
Old 08-09-2011, 03:45 PM
davidkstyler's Avatar
davidkstyler davidkstyler is offline
2005 Ford F-250
davidkstyler is gaining momentum as a positive member of FTE.davidkstyler is gaining momentum as a positive member of FTE.
Quote:
Model Year(s):
FORD / E-250
2002-2007
FORD / E-350
2002-2007
FORD / E-450
2002-2007
FORD / E550
2002-2007
FORD / EXCURSION
2002-2005
FORD / RANGER
2004-2011
    11V352000
  • Summary:
  • Consequence:
  • Remedy:
  • Notes:
Under Model Year did you mean to type Fxxx?
__________________
2005 F250 6.0 PSD XL 2WD LB, Fumoto valve, Edge Insight, Edge Exhaust Pyrometer, GlowShift Fuel Pressure guage, Blue Spring, BulletProof EGR, Cat ELC, Homemade Coolant Filter, Ravelco, Red Head Steering Gear
  #9 (permalink)
Old 08-10-2011, 09:56 AM
frhrwa frhrwa is offline
2002 Ford F-Super Duty
frhrwa is starting off with a positive reputation.
recall
what about the Ford F-250 7.3 supercab 4X4? and why haven't they taken responsibility for the bad electronics.. mine went bad 2 weeks after I bought the truck.. windows won't roll down or up half the time, back up alarm won't stay on at all, overdrive light stays on all the time, gas gauge shows empty now and then, all sorts of weird electronic problems, you never know what to expect when you start the truck.. but, THEY say they have no problems.. seems like there are a lot of FORDS with these problems that THEY don't want to address.. my neighbors was so bad, he gave it back to them less than a month after buying it, made them take it back!
  #10 (permalink)
Old 08-10-2011, 11:06 AM
Quote:
Huh?
I cut and pasted the information directly from the recall center data.
__________________
  #11 (permalink)
Old 08-10-2011, 12:32 PM
2005 Ford F-250
Huh?
Thanks for the update, I'm just a little confused! I thought the recall was for F250s but your cut & paste shows it's for E250s. Is the recall for the trucks or for the Econolines? Or both?
__________________
  #12 (permalink)
Old 08-10-2011, 12:58 PM
2005 Ford F-250
Report Date : August 10, 2011 at 01:56 PM
NHTSA CAMPAIGN ID Number: 11V352000
Vehicle Make / Model: Model Year(s):
FORD / EXCURSION 2002-2005
FORD / F-250 2002-2004 2007
FORD / F-250 SD 2002-2004
FORD / F-350 2002-2007
FORD / F-350 SD 2002-2004
FORD / F-450 SD 2002-2007
FORD / F-550 2004
FORD / F-550 SD 2002-2003 2005-2007
FORD / F250 2005-2006
FORD / F250 SUPER DUTY 2005-2007
FORD / F350 SUPER DUTY 2005-2007
FORD / F450 SUPER DUTY 2004-2007
FORD / F550 2003
FORD / F550 SUPER DUTY 2004-2007
FORD / RANGER 2004-2011
Manufacturer: FORD MOTOR COMPANY Mfr's Report Date: JUL 07, 2011
NHTSA CAMPAIGN ID Number: 11V352000 N/A
NHTSA Action Number: N/A
Component: EXTERIOR LIGHTING:BRAKE LIGHTS
Potential Number of Units Affected: 26,715
Summary:
Consequence:
Remedy:
Notes:
They must have updated the posting, it is now for the trucks.
__________________
  #13 (permalink)
Old 08-10-2011, 01:56 PM
Ahh, I understand now. Hadn't noticed the E series. Thanks!
__________________
  #14 (permalink)
Old 09-08-2011, 11:18 AM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
2005 Ford Excursion
Misky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud ofMisky6.0 has much to be proud of
Anybody get notified yet?
I'm thinking of calling my local Ford dealer and asking, but I've
been so busy I had forgotten about this....
__________________
2005 EB Excursion 2wd 6L PSD 3.73/LS Mich LTX M/S2, Diesel Kleen (gray bottle), RAS, Read Head Steering, scangaugeII w/Blendmount, SPAtechnique gauge (Fuel Pressure & Volts), blue spring, Air Lift 1000 air springs, Interior Dome Override, DieselSite Coolant Filter, BPD Oil & EGR coolers, Rancho RS9000, Hellwig, Diehard Platinum x2 (mine)
2004 EB Explorer 4x4 stock (hers)
2000 Jeep Sahara 4x4 2" lift, Warn winch, detroit lockers front and rear (ours)
  #15 (permalink)
Old 09-14-2011, 11:49 AM
Misky6.0's Avatar
2005 Ford Excursion
According to FMC, 11C18 is conditional and only applies
to certain Ex (at least for my '05 MY). IF my Ex was having
problems now (or perhaps had the multi-function switch
previously replaced) I would have been included in the recall.
__________________
Tags
11c18, 11v352000, 20022004, 20022007, bed, campaign, f250, f450, ford, id, info, nhtsa, number, pickup, recall, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
