transmission coolant lines
I'm in the midst of changing my rear main seal. When removing one of the tranny coolant lines at the transmission; the line caught on the compression nut (yes I was loosening the right nut) and the line twisted and eventually broke right at the fitting. The line is twisted about 2 to 3 inches from the fitting. I'm guessing I need to make a patch line?
I went to the auto parts store (pep boys) and all they had was rubber lines! I looked at brake lines that come with the fittings and they seem more than adequate. They seemed better than the tranny lines. Can I use one of these brake lines? What size do I need? I have a flaring tool, and I can obtain a double ended compression nut to fit the ends together. Any advice please.
Thank You in Advance!
moosinatrix
11-01-2012 07:42 AM
carnut122
13
10-22-2011 07:12 PM
Pele
06-02-2007 09:21 AM
MAHinton
07-04-2005 02:30 PM
