Radiators once again covered if you have a rad hose o-ring leaking - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 11-12-2014, 05:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
Print Wikipost
Old 07-19-2011, 11:43 PM
jboczar jboczar is offline
jboczar has a good reputation on FTE.jboczar has a good reputation on FTE.
I decided to start a new post since the other one has gotten so long.
So, once again Ford has updated this TSB. First it was the venturi tee that was causing radiators to break, then it was hyper-extended thermostasts, and now it is the leaking o-rings inside rad hoses that cause low coolant which stresses the radiator causing it to break.
So for everyone, the new TSB is 11-6-6. As part of this tsb, if you have a leaking o-ring inside one of the rad hoses or the appearance of dried coolant indicating a leak and your radiator is leaking then all of the repair is CODED to 8590 which is the o-ring which is covered for 5 years/100000 miles.
As part of the repair, they replace either or both radiator hoses-they have been redesigned to include 2 o-rings. The radiator is replaced of course, as well as the reservoir and cap. Which is why as of this posting, the reservoirs are on national back order.
So if you have a leaking radiator, take a good look at those hoses and see if they are leaking as well and it will be covered by the warranty.
I feel bad for all those people who had to pay out of pocket for a radiator repair when it may have been simply caused by a cheap o-ring that now Ford is covering under warranty.
Old 07-20-2011, 07:09 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Here is the TSB:
[************]Printable View (7677 KB)[/color]
TSB
11-6-6 • 6.4L - RADIATOR LEAKING COOLANT
[************]Publication Date: June 3, 2011[/color]
FORD: 2008-2010 F-250, F-350, F-450, F-550
This article supersedes TSB 11-1-7 to update the Issue Statement, Service Procedure, Part List and Service Labor Time Standards. ISSUE:
Some F-Super Duty vehicles equipped with a 6.4L engine may exhibit an external coolant leak from the radiator. Slow leaks at cooling system hoses/connections can lead to low coolant levels. Excessive hot and cold cycling associated with low coolant levels can cause stress within the radiator tubes, possibly resulting in cracks in the tubes.
ACTION:
Follow service procedure steps to repair this concern.
SERVICE PROCEDURE
Thermostat inspection is no longer required because IDS release 71.04 and later added a cooling system monitor.
1. Inspect for the cooling system venturi tee being installed and verify proper orientation. Refer to Workshop Manual (WSM), Section 303-03, Degas Bottle - 6.4L Diesel.
2. Degas bottle port inspection and repair:
1. Dual-port design requires the degas bottle to be replaced with the single-port design and a new degas bottle cap. (Figure 1) Proceed to Step 3.
Figure 1 - Article 11-6-6
2. Single-port design requires inspection of the degas bottle cap sealing surface for nicks and/or cracks. If present, replace the degas bottle and degas bottle cap. Proceed to Step 3.
3. Coolant leak inspection and repair:
1. Visually inspect all cooling system hoses/connections for evidence of coolant loss such as white coolant residue (dried coolant) or liquid coolant and repair as necessary. (Figure 2)
Figure 2 - Article 11-6-6
2. If a leak is found at a radiator hose O-ring seal, the radiator hose should be replaced. The upper and lower radiator hoses have been updated with a dual O-ring seal design for improved sealing.
4. Replace the radiator. Refer to WSM, Section 303-03.
1. Be sure to remove the engine coolant block plugs from both sides of the engine to drain the coolant from the engine block.
2. Fill the cooling system with a 50/50 mixture of distilled water and new Motorcraft® Premium Gold Engine Coolant. Do not reuse coolant that was drained from the cooling system.
3. Utilize the Rotunda Heavy Duty Airlift II radiator refiller tool (UVU550500INT) or equivalent when filling the cooling system. Filling without use of the Heavy Duty Airlift II radiator refiller tool may leave excessive air in the system
PART NUMBER PART NAME
8C3Z-8009-B Radiator
9C3Z-8A080-AA Degas bottle
9C3Z-8101-B Cap- Degas bottle
AC3Z-8260-A Upper Radiator hose
AC3Z-8286-A Lower radiator hose
8C3Z-8B379-B Venturi Tee
VC-7-B Motorcraft® Premium Gold Engine Coolant
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
110606A 2008-2010 F-Super Duty 6.4L: Inspect The Cooling System, Correct Or Install Venturi Tee, Replace The Radiator, Includes Time To Drain And Fill The Cooling System (Do Not Use With Any Other Labor Operations) 2.8 Hrs.
110606B 2008-2010 F-Super Duty 6.4L: Inspect The Cooling System, Correct Or Install The Venturi Tee, Replace The Degas Bottle And Cap If Necessary, Replace The Radiator, Includes Time To Drain And Fill The Cooling System (Do Not Use With Any Other Labor Operations) 3.2 Hrs.
110606C 2008-2010 F-Super Duty 6.4L: Inspect The Cooling System, Correct Or Install Venturi Tee, Replace The Upper And Lower Radiator Hoses, Replace The Radiator, Includes Time To Drain And Fill The Cooling System (Do Not Use With Any Other Labor Operations) 2.9 Hrs.
110606D 2008-2010 F-Super Duty 6.4L: Inspect The Cooling System, Correct Or Install The Venturi Tee, Replace The Degas Bottle And Cap If Necessary, Replace The Upper And Lower Radiator Hoses, Replace The Radiator, Includes Time To Drain And Fill The Cooling System (Do Not Use With Any Other Labor Operations) 3.3 Hrs.
MT110606 For Any Additional Cooling System Repairs Use SLTS Operations If Available Or Actual Time Actual Time
DEALER CODING
BASIC PART NO. CONDITION CODE
8009 (Operations A or B) 42
8590 (Operations C or D) 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2011 Ford Motor Company
Old 07-20-2011, 07:00 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Also sucks for those of us that had a bad O ring and all they did was replace it and nothing else. Kind of hoping for another O ring leak now. Wonder if they extend that O ring warranty if you buy the 2/100K warranty.
Old 07-20-2011, 07:09 PM
homepukes's Avatar
homepukes homepukes is offline
homepukes is starting off with a positive reputation.
how do I make it leak to get it fixed under warranty?
Old 07-20-2011, 10:52 PM
jrtraderny jrtraderny is offline
jrtraderny is gaining momentum as a positive member of FTE.
Quote:
Easy, drive it ...............
Old 07-21-2011, 07:43 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Good info, added to tech folder!
Old 07-21-2011, 08:36 AM
Larry NCKS's Avatar
Larry NCKS Larry NCKS is offline
Larry NCKS is starting off with a positive reputation.
Doggone it! My upper radiator hose cost me a short year ago. Are they saying it now has the 100,000 mile/5 year warranty too?
Old 07-21-2011, 09:44 AM
F250Wheels F250Wheels is offline
F250Wheels is starting off with a positive reputation.
I just replace the lower hose o-rings, Before I did it I called ford service and was told not covered under 5/100 warranty.
Old 07-21-2011, 10:40 AM
smotrs's Avatar
smotrs smotrs is offline
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
I haven't had a radiator issue yet other then the addition of the venturi, but good to know if that changes.
Old 07-21-2011, 02:03 PM
RickyD RickyD is offline
RickyD is starting off with a positive reputation.
My dad just got bent over to the tune of $1157.00 for a radiator less than a week ago. I was told he was getting a break on labor as well as parts(ya right) I am pretty sure it won't do any good but I will contact the service mgr. to see if they can go back on this tsb.
Old 07-21-2011, 04:35 PM
Quote:
O-rings insided the radiator hoses have a basic code of 8590. When coded this way, it is covered for 5yrs/100,000 miles.
Old 07-21-2011, 08:05 PM
The cost for o-rings wasn't bad, But it would have been nice to get new hoses.
Old 07-21-2011, 08:30 PM
Sounds like you need a new dealer if they wouldn't replace them under warranty, had mine done late last year with 73K miles all covered under warranty.
Old 07-21-2011, 10:49 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
Quote:
Looks to be dated june 3, print it out and take it with you. I don't think they have a leg to stand on. They probably just didn't know about it.
Old 07-22-2011, 11:31 AM
Surfer44's Avatar
Surfer44 Surfer44 is offline
Surfer44 is starting off with a positive reputation.
POOR MPG
My dealer told me it was not covered. I had 25K on the truck but 37 months. They denied it "on time". Service manager said that "it's normal for the o-rings to go bad at 25K.
I've had Ford trucks since 1970. This 2008 F350 CC 4X4 King Ranch will be my LAST Ford ever (POS engine). 10.3 MPG AVG and 7.5 pulling. Dealer tells me "that is good".
Tried a Diablo Predator tuner, BIGGEST POS on the market. Got WORSE MPG.
Going to try Dodge 3500 4X4 Longhorn next.
V10 Thermostat Replacement "How To" Tom Excursion - King of SUVs 15 02-09-2017 04:59 PM
Upper Radiator Hose Leak MammaJammaTX 6.7L Power Stroke Diesel 5 12-26-2016 06:19 PM
RADIATOR & HOSES WARRANTY COVERAGE PSDx3 6.4L Power Stroke Diesel 10 02-07-2016 01:36 PM
Milky oil Turbolover64 1994.5 - 1997 7.3L Power Stroke Diesel 12 01-30-2016 09:53 PM
Transmission radiator quick disconnect fittings leak fix BigBlueX 6.0L Power Stroke Diesel 1 09-04-2015 01:39 PM
Tags
1166, 2008, 46, duty, explorer, f350, ford, hose, labor, oring, radiator, replace, rings, super, time, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
