6.0 loss of power
Old 07-19-2011, 10:06 PM
Mr.Greg's Avatar
Mr.Greg
Mr.Greg is offline
6.0 loss of power
I have a 2004 6.0 diesel.....when pulling a trailer it loose's power going up a long hill.....Any suggestion please?.....I have changed the fuel filter and fuel pump...dropped fuel tank...checked sending unit screen...acts like it runs out of fuel...
Old 07-19-2011, 10:12 PM
Roasted7's Avatar
Roasted7
Roasted7 is offline
How's your coolant and oil temps? You need to know this. Do you have scangauge II? Dash gauges don't mean nothing.
Checked for boost leaks? cac tube boots cracked?
Old 07-19-2011, 11:02 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
It could be lots of things get a SGII to start reading things
at a guess bad or dirty egr valve
or at least get codes scaned at auto part store
Old 07-20-2011, 02:30 AM
bismic's Avatar
bismic
bismic is online now
Received 2,449 Likes on 1,696 Posts
As Benny said, checking for codes is always a wise thing to do (you can have stored codes without a CEL).
Is your 2004 an early model year (ie the ICP sensor behind the turbo)? Check the ICP sensor connector and see if it is leaking oil. Disconnect it and see how it runs.
Also, you may want to check FICM voltage.
There is a low power troubleshooting thread in the Tech Folder.
https://www.ford-trucks.com/forums/9...condition.html
pjohn192
12-19-2023 10:45 AM
Tom Callan
05-27-2017 03:53 PM
04kingrancher
02-07-2017 06:42 PM
dkimmer
01-22-2016 02:09 PM
Cowboy1412
11-11-2015 07:20 AM
Quick Reply: 6.0 loss of power
