Can you still order an F150? - Ford Truck Enthusiasts Forums
Old 07-19-2011, 09:02 PM
swanee swanee is offline
swanee is gaining momentum as a positive member of FTE.
Can you still order an F150 and when will there be any information on 2012Thanks
Old 07-19-2011, 09:18 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
MODEL(S): 2011 Ford F-150 Regular Cab and Super Cab/ Super Crew
PROD LEAD TIME (WKS): 14-16 (A)
PROD RESTRICTIONS:
- Raptor (W1R, X1R) are allocated for retail only
- Lariat Limited package has been built out and is no longer available to order
- Bed Liner (96W, 96P) may increase lead time by 4 weeks or more
- Tuxedo Black (UH) and Red Candy (U6) paints have been built out for the model year and are no longer available to order
- Navigation Radio (58N) has been built out and is no longer available to order. This option will also be unavailable for the 2012 MY
- Super Crew body style may increase lead time by 4 weeks or more
- F-150 Tires (T7E) may increase lead time by 2-4 weeks. Suggested alternatives are T8B and T7B
Old 07-19-2011, 10:15 PM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to behold
Quote:
Latest order cut off date for MY11 is August 19th. Just remember though that the longer you wait the greater chance that a option you may want will not be available leaving you with a unbuildable unit.
MY12 ordering information should be available sometime between the middle and end of August.
PROD RESTRICTIONS:
From what I have seen Ford has not completely eliminated navigation for MY12 although nothing is set in stone either. At this point it is still showing with a Job 1 date of TBD.
T7E tires were supposed to be changed to free demand status as of July 7th and were expected to be good to go through model year balance out. Ford was able to get a supplier commitment to double the number of tires available for production.
Old 07-20-2011, 08:56 AM
Thanks. I think I'll go today.
Old 07-20-2011, 10:04 AM
ThirdsACharm's Avatar
ThirdsACharm ThirdsACharm is offline
ThirdsACharm is starting off with a positive reputation.
I ordered mine on Friday (7/15).
Had to go with Ebony Black as per the supply issue with the tuxedo color.
Salesmen estimated 6 weeks. A knowledgable source here on FTE told me to bet more on 10 weeks given the shipping situations lately. We shall see. I am really excited - never had a truck built for me before.
Old 07-20-2011, 02:27 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
a little off topic, but what are the changes for MY2012? I assume only minor things like color and options.
1978 Ford F150 build sheet template/guide? pryorstemmed 1973 - 1979 F-100 & Larger F-Series Trucks 8 01-11-2017 08:50 AM
when is the last day to order 2016 f 150 Daveyf15096 2015+ F150 3 07-07-2016 09:02 PM
Ordering 2017 F-250 Dustin Morris 2017 Super Duty 35 04-21-2016 11:17 AM
82 f-150 302 duraspark III- Need Timing Order jim1234 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 03-16-2016 06:34 PM
1976 f150 4x4 highboy Sally Salazar 1973 - 1979 F-100 & Larger F-Series Trucks 33 12-09-2009 12:48 PM
Tags
150, 2011, 2012, allocated, f, f150, ford, lead, navigation, order, raptor, retail, time, truck, trucks, w1r, x1r
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
