Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 07-19-2011, 07:51 PM
Dags's Avatar
Dags Dags is offline
Garage is empty, add now
Dags is starting off with a positive reputation.
Engine mounts
Can anyone in the Aussie chapter help me to source, or point me in the right direction, a set of engine mounts to put the 460 into my '79 4x4.
It had the 351c in it and it's proving hard to find info about them.
__________________
REAL CARS ARE CHEAPER
  #2 (permalink)
Old 07-20-2011, 02:45 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
have no idea but did a bit of a search for ya
West Coast Broncos: WCB Extreme Duty Motor Mounts 429-460
will they do ??
heres a link to an old write up about it
http://www.7879blueovalbronco.com/fo...php/t-834.html
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #3 (permalink)
Old 07-20-2011, 03:32 AM
Dags's Avatar
will they do ??
460 Swap [Archive] - 7879BlueOvalBronco.com - Ford Bronco and F-series Truck Forums
Thanks Brian.
The West Coast Bronco mounts will bolt to the 460 obviously, but I'n not sure of attatching them to the 351c mounts.
I am really hoping to have enough mount to be able to drill a hole through the whole lot and run a bolt through it, (left one) instead of chaining the block down.
That writeup was a good read but the thought of lifting that big hunk of iron in and out doesnt sit well. It'll be enough of a headache if I decide to get a set of mandrel headers made. lol
__________________
  #4 (permalink)
Old 07-20-2011, 06:33 PM
so the existing mounts are modified to accept the 351. is that right.
Whats the 79. a F150 ??
__________________
Brian
  #5 (permalink)
Old 07-20-2011, 06:38 PM
Dags's Avatar
It was a 351c. The '79 has towers with a biga** hole in the centre and nothing I've seen so far looks anything like that.
Because our American friends didn't get the 351 option in the '79 4x4 they have no mounts for it, unless the 351m are the same, then I can buy them on ebay.
LMC have 302 to 460 mounts and these sound like the only ones that will work, but they look a bit flimsy for the hp I should have.
__________________
  #6 (permalink)
Old 07-20-2011, 08:01 PM
never had the pleasure with LMC but I have read a few post about there poor quality materials. Flimsy chinese $hi#.
__________________
Brian
  #7 (permalink)
Old 07-21-2011, 04:17 PM
xran's Avatar
xran xran is offline
2007 Ford Falcon
xran is starting off with a positive reputation.
Chinstrike
The guys in Osborne Park don't have anything? I can't remember their name but they have all the US cars and trucks...
__________________
THE YARD - 1994 turbo'd Fairmont 280rwhp @ 6psi, 1994 Ute w/351C SKID PIG, 2007 XR6turbo 433rwhp 11.8 @ 120mph shopping trolley, 1974 F-100 trayback 302C, C4, 9"
  #8 (permalink)
Old 07-21-2011, 04:26 PM
BigF350 BigF350 is online now
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
I am pretty sure the engine mounts for the Windsor/351C are the same.
Check in the 335 series engine forum though - I know the 351M/400M shares its bell housing with the 351C, but I am pretty sure the 351 has the same mounts as the small block.
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #9 (permalink)
Old 08-04-2011, 10:30 PM
xran's Avatar
2007 Ford Falcon
Chinstrike
Yep, Whinger and Clevo mounts are interchangeable.
Both sets of mounts are different between small/big-blocks though. Pacemaker does a mounting kit for 429/460 into XD-XF along with a set of pipes, but being different bays you'd have to make up mounts for the body mounts to adapt them hahaha, so it's a bit of a redundancy... I will ask a mate who changed from a clevo to a 460 in a '56 and see if he had to change body mounts or not. That should sort you out
__________________
  #10 (permalink)
Old 08-05-2011, 01:23 AM
xran's Avatar
2007 Ford Falcon
Chinstrike
Just spoke to him and he said he used a set of mounts (body and engine) from the mid-80's EFI 460 trucks, and adapted them to the body of his '56. That was only a stock LPG motor with a tunnel ram though, not a 557... so maybe the body mounts with the hardcore Bronco mounts above might get you home?
I think your bay should be the same as mine, and he reckoned it would be even easier to do my '74 than doing the swap in his was.
__________________
  #11 (permalink)
Old 06-21-2012, 12:07 PM
xran's Avatar
2007 Ford Falcon
Chinstrike
Did you end up getting this one sorted out Dags?
__________________
Tags
460, 7879blueovalbronco, broncos, coast, motor, mount, mounts, towers, west
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
