Installing 08 Mirrors on 04 with pics. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-19-2011, 07:33 PM
Firemudder's Avatar
Firemudder Firemudder is offline
Firemudder is starting off with a positive reputation.
Today my new 08 mirrors came in and I had the time to install them. Here is a little write up on how I did it.
First need to remove the window control panel. Make sure you pry up on the front of the panel so you don't break the rear plastic tab. Then just unplug the four plugs.
Then with a 7mm nut driver remove the top bolt hidden by the window panel.
With the same driver remove the lower bolt behind the red deflector.
Now you can take off the door panel by just lifting it straight up. No plastic tabs to remove.
With a 5.5mm socket remove the 4 bolts that hold the speaker on.
More on next post.
Old 07-19-2011, 07:44 PM
Firemudder's Avatar
Now with a 11mm socket remove the four bolts holding on the mirror. Just remove the two rubber plugs towards the front of the truck. The middle one stays there.
For the last 2 nuts you have to peel back the grey sticky stuff to see them.
Before you remove the mirror it's a good idea to have someone holding it on the other side. Now you can unplug the mirror plug which is behind the grey sticky stuff. It may take a little force to remove the old mirror due to the seal being there for a while.
Now the new plug will not fit the old plug inside the door. So I went and cut the plug end off the old mirror and spliced it into the new mirror.
Before you install the new mirror you will have to cut a little plastic tab off. I used a Dremel tool and it came off very easily.
There is one too many wires on old plug and two yellow ones. So I found the one that works and went from there.
Now after everything is spliced together just reverse the steps and its all done. Took me about a hour just going at a slow pace.
I love these new mirrors. They look great and much more functional.
Old 07-19-2011, 07:47 PM
98SurplusExpy 98SurplusExpy is offline
98SurplusExpy is gaining momentum as a positive member of FTE.
Neato ... thanks for the visual write-up!
Old 07-19-2011, 08:08 PM
rockcrawler_101 rockcrawler_101 is offline
rockcrawler_101 is gaining momentum as a positive member of FTE.rockcrawler_101 is gaining momentum as a positive member of FTE.
Love the 08 mirrors on my work truck! Can't wait to find a decent price for some for my 01.
Old 07-19-2011, 08:14 PM
Firemudder's Avatar
Found mine on ebay. Do a search the same guy has more sets.
Old 07-20-2011, 11:40 AM
raptor8719's Avatar
raptor8719 raptor8719 is offline
raptor8719 is starting off with a positive reputation.
lookin good
Old 07-20-2011, 12:05 PM
Craig.Parks's Avatar
Craig.Parks Craig.Parks is offline
Craig.Parks is starting off with a positive reputation.
Thanks for the write-up and pics. That's one of my planned mods as well.
Old 07-22-2011, 05:52 PM
97 Triton's Avatar
97 Triton 97 Triton is offline
97 Triton is starting off with a positive reputation.
Looks good, now you need to post up some side pics.
Old 11-18-2012, 10:59 PM
BstatusV BstatusV is offline
BstatusV is starting off with a positive reputation.
Did you need to replace the panel mirror control switch? Or is it the stock switch? Are you able to retract/extend/fold the mirrors?
Old 11-19-2012, 12:26 AM
boucheath boucheath is offline
boucheath is starting off with a positive reputation.
Old 12-01-2013, 02:55 PM
Super Duty Diablo's Avatar
Super Duty Diablo Super Duty Diablo is offline
Super Duty Diablo is starting off with a positive reputation.
Great write up! Does anybody know the cheapest place to get the new square mirrors?
Old 12-01-2013, 07:09 PM
nico963's Avatar
nico963 nico963 is offline
nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.
This is where I bought mine from.This is the cheapest place I found.I'm really happy with mine.
Here's some power,heated with signal lights
2004 Ford F250 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair at 1AAuto.com
Here are a pair of bare bones,No power,no heat and no signal
2004 Ford F250 Truck Manual Telescoping Upgrade Mirror Pair at 1AAuto.com
Old 12-01-2013, 07:36 PM
OK. They are the newer style but I guess they fit the older trucks. I am assuming they are direct plug in? Mine are power but do not have heat or turn signals. Will these new ones still work?
Old 12-01-2013, 07:49 PM
nico963's Avatar
Quote:
Yes they are the newer style and they've designed them to fit the older trucks.Mine for my 07 were plug and play.But I also have power heated with turn signals.
It looks like these are what your looking for.There're power but don't have heat or turn signals.
2004 Ford F250 Truck Power Telescoping Upgrade Mirror Pair at 1AAuto.com
Old 12-01-2013, 08:28 PM
Yes! That's it. Thanks a bunch man!!
Fantasy Graphics - All Hot Rods jimtete General NON-Automotive Conversation 211 08-29-2016 04:01 PM
Possible 1/4 tank fuel problem fix. Firemudder 6.0L Power Stroke Diesel 6 01-05-2015 03:48 PM
GTG pic's and a 56k warning sglaine New Hampshire Chapter 39 08-03-2009 09:59 PM
Sept meet pic's sglaine New Hampshire Chapter 41 09-11-2008 11:23 AM
my f100 custom cabby 1967 - 1972 F-100 & Larger F-Series Trucks 5 05-27-2008 12:12 PM
Tags
01, 08, 09, 99, door, econoline, f350, ford, forum, installing, mirror, mirrors, panel, power, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
