1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Installing 08 Mirrors on 04 with pics.
Old 07-19-2011, 07:33 PM
Firemudder's Avatar
Firemudder
Firemudder is offline
Today my new 08 mirrors came in and I had the time to install them. Here is a little write up on how I did it.
First need to remove the window control panel. Make sure you pry up on the front of the panel so you don't break the rear plastic tab. Then just unplug the four plugs.
Then with a 7mm nut driver remove the top bolt hidden by the window panel.
With the same driver remove the lower bolt behind the red deflector.
Now you can take off the door panel by just lifting it straight up. No plastic tabs to remove.
With a 5.5mm socket remove the 4 bolts that hold the speaker on.
More on next post.
Old 07-19-2011, 07:44 PM
Firemudder's Avatar
Firemudder
Now with a 11mm socket remove the four bolts holding on the mirror. Just remove the two rubber plugs towards the front of the truck. The middle one stays there.
For the last 2 nuts you have to peel back the grey sticky stuff to see them.
Before you remove the mirror it's a good idea to have someone holding it on the other side. Now you can unplug the mirror plug which is behind the grey sticky stuff. It may take a little force to remove the old mirror due to the seal being there for a while.
Now the new plug will not fit the old plug inside the door. So I went and cut the plug end off the old mirror and spliced it into the new mirror.
Before you install the new mirror you will have to cut a little plastic tab off. I used a Dremel tool and it came off very easily.
There is one too many wires on old plug and two yellow ones. So I found the one that works and went from there.
Now after everything is spliced together just reverse the steps and its all done. Took me about a hour just going at a slow pace.
I love these new mirrors. They look great and much more functional.
Old 07-19-2011, 07:47 PM
98SurplusExpy's Avatar
98SurplusExpy
98SurplusExpy is offline
Neato ... thanks for the visual write-up!
Old 07-19-2011, 08:08 PM
rockcrawler_101's Avatar
rockcrawler_101
rockcrawler_101 is offline
Love the 08 mirrors on my work truck! Can't wait to find a decent price for some for my 01.
Old 07-19-2011, 08:14 PM
Firemudder's Avatar
Firemudder
Found mine on ebay. Do a search the same guy has more sets.
Old 07-20-2011, 11:40 AM
raptor8719's Avatar
raptor8719
raptor8719 is offline
lookin good
Old 07-20-2011, 12:05 PM
Craig.Parks's Avatar
Craig.Parks
Craig.Parks is offline
Thanks for the write-up and pics. That's one of my planned mods as well.
Old 07-22-2011, 05:52 PM
97 Triton's Avatar
97 Triton
97 Triton is offline
Looks good, now you need to post up some side pics.
Old 11-18-2012, 10:59 PM
BstatusV's Avatar
BstatusV
BstatusV is offline
Did you need to replace the panel mirror control switch? Or is it the stock switch? Are you able to retract/extend/fold the mirrors?
Old 11-19-2012, 12:26 AM
boucheath's Avatar
boucheath
boucheath is offline
Old 12-01-2013, 02:55 PM
Super Duty Diablo's Avatar
Super Duty Diablo
Super Duty Diablo is offline
Great write up! Does anybody know the cheapest place to get the new square mirrors?
Old 12-01-2013, 07:09 PM
nico963's Avatar
nico963
nico963 is offline
This is where I bought mine from.This is the cheapest place I found.I'm really happy with mine.
Here's some power,heated with signal lights
2004 Ford F250 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair at 1AAuto.com
Here are a pair of bare bones,No power,no heat and no signal
2004 Ford F250 Truck Manual Telescoping Upgrade Mirror Pair at 1AAuto.com
Old 12-01-2013, 07:36 PM
Super Duty Diablo
OK. They are the newer style but I guess they fit the older trucks. I am assuming they are direct plug in? Mine are power but do not have heat or turn signals. Will these new ones still work?
Old 12-01-2013, 07:49 PM
nico963's Avatar
nico963
nico963 is offline
Yes they are the newer style and they've designed them to fit the older trucks.Mine for my 07 were plug and play.But I also have power heated with turn signals.
It looks like these are what your looking for.There're power but don't have heat or turn signals.
2004 Ford F250 Truck Power Telescoping Upgrade Mirror Pair at 1AAuto.com
Old 12-01-2013, 08:28 PM
Super Duty Diablo
Yes! That's it. Thanks a bunch man!!
Quick Reply: Installing 08 Mirrors on 04 with pics.
