Installing 08 Mirrors on 04 with pics.
Do you know what colors matched up to what wires? I've been looking around online for an hour trying to find a link and keep running in circles...
Now with a 11mm socket remove the four bolts holding on the mirror. Just remove the two rubber plugs towards the front of the truck. The middle one stays there.
For the last 2 nuts you have to peel back the grey sticky stuff to see them.
Before you remove the mirror it's a good idea to have someone holding it on the other side. Now you can unplug the mirror plug which is behind the grey sticky stuff. It may take a little force to remove the old mirror due to the seal being there for a while.
Now the new plug will not fit the old plug inside the door. So I went and cut the plug end off the old mirror and spliced it into the new mirror.
Before you install the new mirror you will have to cut a little plastic tab off. I used a Dremel tool and it came off very easily.
There is one too many wires on old plug and two yellow ones. So I found the one that works and went from there.
Now after everything is spliced together just reverse the steps and its all done. Took me about a hour just going at a slow pace.
I love these new mirrors. They look great and much more functional.
08 Mirrors on 04
Hello,
Are you still happy with the mirrors? Are they holding up well? Would you buy them again?
Thank you.
Thank you.
Today my new 08 mirrors came in and I had the time to install them. Here is a little write up on how I did it.
Attachment 230598
First need to remove the window control panel. Make sure you pry up on the front of the panel so you don't break the rear plastic tab. Then just unplug the four plugs.
Attachment 230599
Then with a 7mm nut driver remove the top bolt hidden by the window panel.
Attachment 230600
With the same driver remove the lower bolt behind the red deflector.
Attachment 230601
Now you can take off the door panel by just lifting it straight up. No plastic tabs to remove.
Attachment 230602
With a 5.5mm socket remove the 4 bolts that hold the speaker on.
More on next post.
Attachment 230598
Attachment 230599
Attachment 230600
Attachment 230601
Attachment 230602
More on next post.
dynamic
394
10-05-2022 05:56 AM
Tylus
11-24-2017 05:47 PM
strokin'_tatsch
20
02-28-2017 06:55 AM
