Installing 08 Mirrors on 04 with pics. - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-01-2013, 09:33 PM
nico963's Avatar
nico963 nico963 is offline
nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.
Quote:
Originally Posted by Super Duty Diablo View Post
Yes! That's it. Thanks a bunch man!!
Anytime brother!
Old 02-15-2014, 05:38 AM
GatorBaitR6's Avatar
GatorBaitR6 GatorBaitR6 is offline
GatorBaitR6 is starting off with a positive reputation.
Can you write out what color wire goes to what. I've read that it's not color matched for the swap and different colors go to each other on the swap. Much appreciated.
Old 02-15-2014, 08:40 AM
MC45 MC45 is offline
MC45 is starting off with a positive reputation.
what mirrors are you putting on the truck? aftermarket, oem? I put oem 2012 power folding mirrors on my 03. wiring on my truck only had power mirror wires.
Old 10-04-2015, 05:24 PM
Stevekron1 Stevekron1 is offline
Stevekron1 is starting off with a positive reputation.
Do you know what colors matched up to what wires? I've been looking around online for an hour trying to find a link and keep running in circles...
Quote:
Originally Posted by Firemudder View Post
Now with a 11mm socket remove the four bolts holding on the mirror. Just remove the two rubber plugs towards the front of the truck. The middle one stays there.
For the last 2 nuts you have to peel back the grey sticky stuff to see them.
Before you remove the mirror it's a good idea to have someone holding it on the other side. Now you can unplug the mirror plug which is behind the grey sticky stuff. It may take a little force to remove the old mirror due to the seal being there for a while.
Now the new plug will not fit the old plug inside the door. So I went and cut the plug end off the old mirror and spliced it into the new mirror.
Before you install the new mirror you will have to cut a little plastic tab off. I used a Dremel tool and it came off very easily.
There is one too many wires on old plug and two yellow ones. So I found the one that works and went from there.
Now after everything is spliced together just reverse the steps and its all done. Took me about a hour just going at a slow pace.
I love these new mirrors. They look great and much more functional.
Old 10-04-2015, 06:24 PM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
Don't forget to check Amazon for prices. I found the lowest prices there for the manual model 08 mirrors for my 02. I found I never adjusted them and didn't care if I have power anything. I used a Dremel to trim the tab on mine too.
Steve
Old 10-04-2015, 07:08 PM
asdrew's Avatar
asdrew asdrew is offline
asdrew is gaining momentum as a positive member of FTE.
Quote:
I did my 05 a few months ago, think I posted some info about that in this thread: http://www.ford-trucks.com/forums/13...l#post15417384
hardcore wheeling pictures KubotaOrange76 Offroad & 4x4 26 12-21-2016 05:10 PM
Fantasy Graphics - All Hot Rods jimtete General NON-Automotive Conversation 211 08-29-2016 05:01 PM
Removing fin fan shroud for good? Firemudder 6.0L Power Stroke Diesel 113 02-23-2015 01:06 AM
Iswnt this odd Old Reliable 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-07-2011 05:44 PM
Check out this Bigfoot cake I made for my son mando jake 1973 - 1979 F-100 & Larger F-Series Trucks 13 12-08-2008 05:06 PM
Tags
01, 08, 09, 99, door, econoline, f350, ford, forum, installing, mirror, mirrors, panel, power, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
