I got a single short leaf with the full floater I bought, The springs came with an angled block about 1.09 on one end and .900 on the other about 6 inches long something like that might work I think they're stock ford.
If my pinion angle is OK I may not mess with it...I have two threads going, i should have just compined it all in one....
Originally Posted by Diesel_Brad
2wd F150 are 2.5"WIDE 4wd are 3"WIDE
Right on, I pulled the 4WD F150 blocks yesterday and they are just shy of 3" wide, 2" high with bump stop wing
Cool, so here are the 2" blocks off the F150 4x4 next to my 4" F350 blocks. They worked perfect, I had to get shorter U bolts from the yard though. BTW looks like there is no taper on either of em.
