Cylinder Contribution Test throws P0196 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-19-2011, 03:35 PM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
I did my first CCT today. Right when I started the test, the engine sort of stumbles for a split second and shows P0196. I ran the test three times and it did the exact same thing each time.
What does a P0196 mean? I can't find it in the "PSD trouble codes" thread. I googled it and it said that it was some sort of EOT sensor malfunction. Can anyone verify this or be more specific as to what problem is indicated by the P0196?
Thanks in advance.
Edit: I forgot to mention that I performed the CCT not long after a cold start, if that makes a difference.
Old 07-19-2011, 03:59 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
I haven't done the CCT myself but I know that the engine needs to be up to operating temp before it will allow the CCT to run. My guess is that the EOT (engine oil temperature) wasn't high enough to allow the test to run. The PCM pays no attention to coolant temp, only EOT.
That's my WAG anyway....
Old 07-19-2011, 04:12 PM
BuckHammer's Avatar
Oh, I didn't know that it had to be at operating temperature. That's the deal, then. Thank you.
Old 07-19-2011, 06:05 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L BIGRED 7.3L is offline
BIGRED 7.3L is gaining momentum as a positive member of FTE.
I also remember reading that oil temp must be at operating temp prior to the test as DIY states.
Old 07-19-2011, 07:54 PM
makomark makomark is offline
makomark is gaining momentum as a positive member of FTE.
Joseph:
The Gents are spot on. The test will fail and then exit if the PCM isn't satisfied that the engine is up to temp. Most all of the "test Caveats" are on that Service CD. Look under the PCED tab, select OBDI, select the correct model and go to 7.3 Diesel Diags, section 18. Then Perform diesel diagnostics. Based on a quick scan, they also give a preferred order to execute the testing sequence. I also found a performance sheet good for test execution and any code/diagnostic notes.
For the few tests I have run, I've filled out the relevent sections of that sheet. Like an oil analysis routine, that data allows establishing a trend line to gauge the health of the engine. Though it isn't running perfectly, it is still in the 'healthy' range.
Old 07-19-2011, 08:16 PM
arkredneck's Avatar
arkredneck arkredneck is offline
arkredneck is starting off with a positive reputation.
Everyone says run the hell out of the truck an then test it my truck fails on different cylinders but It has stage 2s and Jim at rosewood said it's normal
P0143 and P0196 and P0255 daddogg 6.0L Power Stroke Diesel 5 01-18-2015 02:06 AM
Trouble Code P0196 today??? ggadwa 6.7L Power Stroke Diesel 3 04-05-2014 11:17 PM
Cct results always changes 84-250 1994.5 - 1997 7.3L Power Stroke Diesel 4 09-22-2013 06:42 PM
a few new pics of my truck next to a stock truck wadman1 6.0L Power Stroke Diesel 9 12-04-2011 10:49 PM
Code P0541? Rich in CO 1999 - 2003 7.3L Power Stroke Diesel 10 04-08-2011 12:43 PM
Tags
1997, 2002, 73, 73l, boost, code, contribution, cyl, cylinder, diesel, engine, failure, ford, international, malfunction, p0196, powerstroke, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
