Changing to 2011 Leaf Springs on my 2005 - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #31
Old 02-09-2014, 07:11 PM
xmontex4's Avatar
xmontex4 xmontex4 is offline
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
Goot to know! I would love to update to the newer rear springs. I just want to add rear bags for towing when I occasionally do.
  #32
Old 02-10-2014, 03:15 PM
mlux2008 mlux2008 is offline
mlux2008 is starting off with a positive reputation.
Bump... I also would like to know how the ride is from the original 05 springs to the 2011 springs... Looking into doing this on my F350 DRW if I could find the springs gently used...
  #33
Old 02-10-2014, 03:50 PM
xmontex4's Avatar
Got another question, what about traction bars? I know a lot of bolt on ones use the bottom of the axle, is this a no go now that the ubolts are flipped upside down? Also is it possible to use the 08-10 style mounting system or are you required to flip the ubolts?
EDIT: I answered my own question about the traction bars, but I'm still interested if its possible to use the 08-10 ubolt system.
  #34
Old 05-20-2014, 11:18 AM
Quote:
I'm going to bump again lol. Really curious to hear how well the ride is going from the 05 springs to the 2011 springs.. Considering doing that to my truck if I could find some springs.
  #35
Old 05-20-2014, 11:46 AM
xmontex4's Avatar
If you want you can get the hangers then get some 08 lift springs which probably ride better than 99-07 lift springs. That is what I plan to do eventually if i lift the truck a little more, a 5" rear lift spring and drop the block down to a 1" block to total 4" of lift with a better ride.
  #36
Old 05-20-2014, 11:59 AM
Quote:
I've considered doing that. However once he did the 2011 springs, I think that might be an even better route. The one draw back to the 2011 springs is I'll have to remove the stock hangers (nbd to me) and It might want to squat under heavy weight... not a big deal either to me... Looking for more of a better ride more than anything.
Any ideas where I could get a gently used set of 2011+ springs??
  #37
Old 05-20-2014, 12:22 PM
xmontex4's Avatar
Craigslist or eBay probably, best bet would be craigslist i bet because if someone lifted their truck and replaced the springs locally they will probably practically give them away since they wont need them anymore.
For the squatting i was just going to add airbags when i eventually do mine becasue i rarely tow but probably will a lot in the future.
  #38
Old 10-14-2014, 11:02 PM
fordboy2's Avatar
fordboy2 fordboy2 is offline
fordboy2 is gaining momentum as a positive member of FTE.
Txfireman, is your truck sitting at stock height?
Need help identifying headers TxFireman1972 1987 - 1996 F150 & Larger F-Series Trucks 9 08-23-2015 01:33 PM
Finally doing my 08 Leaf Spring Conversion TxFireman1972 1999 to 2016 Super Duty 57 06-04-2014 01:41 PM
Reflective orange "SUPER DUTY" grille letters on 2011 F550 LSchicago2 1999 to 2016 Super Duty 29 04-05-2013 09:33 PM
Future 2011 or Newer Excursion Build (pics) pdombrowicki Excursion - King of SUVs 31 09-14-2012 08:54 AM
Had the windows retinted - LIMO baby!! TxFireman1972 1999 to 2016 Super Duty 28 07-14-2010 02:47 PM
Tags
05, 1999, 2011, f250, f350, ford, grapplers, leaf, pic, pics, rear, specs, spring, springs, terra, ubolt, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
