M5R2? popping out of OD, now no reverse - Ford Truck Enthusiasts Forums
Old 07-19-2011, 02:41 PM
Liemavick's Avatar
Liemavick Liemavick is offline
Liemavick is starting off with a positive reputation.
1990 F150 4.9, 130,000 original miles by me.
Hey all I'm starting to get the feeling its time for a new tranny, but before I make that leap I wanted the FTE experts opinions first. In the last month I noticed as I cruised in OD (5th) if I let off the accelerator it would drop out of gear and into neutral.
I had a weekend planned for a little TLC on my truck, new brakes, brake lines, oil change etc...So i decided to change the Tranny fluid as well and see if it made any difference in my OD issue. A few days of driving and OD is the same and now I can't find reverse without fighting and grinding for a bit. It seems to be getting worse. I used ATF tranny fluid when I did the change, using the one the boyz at Advanced Auto suggested. I did notice when I drained the fluid it was yellowish, and the new stuff I put in was red if that tells ya anything.
The drain plug had a thick buildup of greasy muck on it with the usual tiny shavings and one thin piece of chewed metal about a inch long. It looked like what could be the remenants of a spring from the shifter bushing. So did I screw up something using the wrong tranny fluid or is my tranny just giving up the ghost? What say you all??
Thanks!
Brian
Old 07-19-2011, 03:54 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Popping out of gear is usually a sign that internal bushings are slopped out.
ATF is the correct fluid for the M5OD. It doesn't make much diff which type you use.
Old 07-20-2011, 04:42 PM
Liemavick's Avatar
When you say internal bushings do you mean the ones at the base of the shifter? Thanks,
Brian
Old 07-20-2011, 05:01 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Old 07-20-2011, 08:04 PM
Liemavick's Avatar
Bushing kit ordered, Thank you all.
Brian
Old 07-21-2011, 10:04 AM
jas88's Avatar
No, I mean the bushings (and/or bearings) that keep the input and output shafts and the cluster gear aligned inside the transmission.
No fluid pressure in E4OD 93 7.3 IDIT JeffStrachan Clutch, Transmission, Differential, Axle & Transfer Case 14 02-18-2016 02:30 PM
Tranny Weirdness- disappearing reverse lizzardly 1999 to 2016 Super Duty 6 02-27-2015 12:17 PM
E4OD without 3rd or OD NM3 1987 - 1996 F150 & Larger F-Series Trucks 4 05-23-2013 10:47 PM
'95 460 E4OD Shifts HARD When Warm mdula 1987 - 1996 F150 & Larger F-Series Trucks 33 09-25-2012 11:04 AM
power steering pump whine vettdvr 1999 - 2003 7.3L Power Stroke Diesel 13 09-14-2008 11:40 AM
Tags
1990, 2000, 96, duty, f150, ford, gear, grinding, m5r2, pop, popping, pops, reverse, super, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
