1988 With Low Oil Pressure - Ford Truck Enthusiasts Forums
Old 07-19-2011, 01:56 PM
Brian085 Brian085 is offline
Brian085 is starting off with a positive reputation.
I was looking at a 1988 F150 4x4 today with a 5.0 302 in it. The guy who owns it is a mechanic and said it has low oil pressure when cold. He tested it manualy with another gauge which still shows low oil pressure.
Now he wants to swap engines from another truck he has to fix the problem. The other engine is a 5.8.
What I'm wondering is if a engine swap is the best way or is there something else like a new oil pump that would solve it?
Thanks for any input.
Old 07-19-2011, 02:36 PM
KevinGnWV's Avatar
KevinGnWV KevinGnWV is offline
The village idiot.
KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.
More than likely the engine is just worn out and a 5.8 swap is a good upgrade IMO. The oil pump is most likely not the issue.
Old 07-19-2011, 02:41 PM
Yeah that’s how he was coming across but it’s worth to get more than one opinion I think.
Old 07-19-2011, 03:13 PM
KevinGnWV's Avatar
The village idiot.
Quote:
Originally Posted by Brian085 View Post
Yeah thatís how he was coming across but itís worth to get more than one opinion I think.
Always a good idea to get a 2nd opinion, or third lol. So...he's going to swap the engines then sell it to you? Is he charging you extra for this? How much is he asking for it if you don't mind saying?
Old 07-19-2011, 03:15 PM
Well as it sits now he said he has $1200 with tags into it. Really its driveable now but he thinks it will start knocking soon.
Old 08-08-2011, 12:13 PM
Anyone else have an opinion? I was talking to him today and it seems I misunderstood with it having low oil pressure when cold. He said today that on start up when cold, the oil pressure is fine, but once it warms up it gets low.
He said its at about 30psi when cold on start. The oil looked low on the dipstick, maybe about a quart low.
It is still best to swap engines?
Old 08-08-2011, 12:19 PM
SCRebel's Avatar
SCRebel SCRebel is offline
SCRebel is starting off with a positive reputation.
Whats the psi when hot. The 302 is not a high oil psi motor. anything above 5 psi is in the green for a 302. I live in conway, SC I run 10w40 oil. I have 10 psi when the motor is hot, and on not days with stop and go traffic it might drop as low as 8 psi. Also I had a 87 f150 5.0 that only had 5 psi when idling. 5 psi and ^ is good.
Old 08-08-2011, 12:27 PM
Not sure on the psi, but low enough for the oil pressure light to come on.
Old 08-08-2011, 12:35 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
It makes since that it is fine when cold. When it warms up, the oil thins out and it has pressure issues. Sound like the bearings are about worn out. Time for another engine
Old 08-08-2011, 02:59 PM
1800joedaddy's Avatar
1800joedaddy 1800joedaddy is offline
1800joedaddy is starting off with a positive reputation.
The oil is supplied to the cranks main journals via oil gallies, like arteries. As the gap between main bearings and journals increase the oil slips by and leaks into the oil pan.
Hence your pump is most likely fine just have worn bearings.
Old 08-08-2011, 03:07 PM
SCRebel's Avatar
You can try running a thicker oil if you don't have the money to fix, swap, or rebuild.
Old 08-08-2011, 03:14 PM
bigred1992's Avatar
bigred1992 bigred1992 is offline
bigred1992 is starting off with a positive reputation.
And if you run thicker oil be sure to add some lucas oil stabilizer or the like. My truck has the death rattle and I'm just going to run it like this as long as I can, which I'm thinking can be a long time.
Old 08-08-2011, 03:22 PM
I might just have the guy swap the 5.8 in. How much do you guys think it should be worth? I'm in Maryland.
Old 08-08-2011, 03:31 PM
I sell running V8's by the cube. A 351 is $350.
Old 08-08-2011, 03:32 PM
Well how much should I pay for the 1988 F150 4x4 with the 5.8 swapped in? I don't already own the truck, I'm looking to buy.
'02 4.6L "Low Oil Pressure" quick35th Explorer, Sport Trac, Mountaineer & Aviator 6 05-09-2013 10:04 AM
OIL PRESSURE GAUGE PROBLEM wcerqua 1987 - 1996 F150 & Larger F-Series Trucks 6 02-20-2012 08:11 PM
302 low oil pressure - in Explorer 2001 EB SoNic67 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 23 11-17-2010 04:51 PM
Swap 302 out for ? 1988 F250 4x4, 5 spd, dually. PonchoV8 Engine Swaps 17 04-28-2010 05:55 PM
351C low oil pressure when hot mudder460 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 26 07-07-2009 01:23 AM
Tags
1988, 460, 50, 58, f150, f350, ford, gauge, idiot, lose, losing, low, oil, preasure, pressure, truck, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
