Sagging Doors - hinges?
Hey All,
I have an issue with the doors on my 55, both of them sag when opened. I've put new weatherstripping on them, and adjusted the hinges for a nice gap around. But when I open them they sag, you have to 'lift" on the handle when closing (or slam)
Is it typically the hinge pins that wear? Can i replace them, or do I have to get entirely new hinges (I'ld like to avoid that as my hinges are painted to match)
Thanks
Mike
Thanks
Mike
Mid fifty sells door hinge pins for replacement. They are made oversize. 11/32"
You will likely have to remove the hinges from the truck to drill the holes oversize to match the new pins.
Mid Fifty F-100 Parts - Home
brian...
brian...
Okay I'm not sure how your problem is showing up but if your latch isn't lining up correctly you might need to adjust the striker plate on the cab/door frame itself. Just a suggestion/thought but the Mid-Fifty bearclaw latch kits sure worked great on my '53 cab and I would say put the money toward those instead, unless you really into the OEM stuff.
Yes, I have replaced them on my 56. Remove the hinges, drive out the old pins (easier said than done), drill the hinge out to the size of the new pin, drive in the new pins and reinstall the hinges. It really makes a world of difference in how your doors operate and is well worth the effort. I bought my replacement hinge pins from C&G Early Ford Parts... can't remember why I didn't use Midfifty but there probably was a reason (CRS is a PITA).
That will depend on exactly what the problem is, and we can't tell from our house. If you simply have worn pins, then replacing them will probably work. If the holes are ovaled out, then drilling and installing the oversize pins may be necessary to cure the issue. If your problem is deeper, like broken hinges or rusty doors or cab pillar, then of course, new pins won't be much help there.You'll need to do your own investigation to figure out what is wrong, and make a repair plan accordingly.
Subzero68
08-21-2016 06:43 PM
BainbridgeBrewer
05-20-2016 11:07 PM
jimrdrnr
04-10-2010 10:09 AM
