Bilstein steering stabilizer
Hey all,
I did search first. Does this Bilstein steering stabilizer fit in the location pictured below? Not sure if that bracket on the steering is O.E. or aftermarket like the stabilizer now. I know I can move that bracket on the steering to make up for length and some pics I've found looks like the stabilizer has the correct ends, I just want to verify. Thanks.
Here's the Bilstein I'm looking at,
Amazon.com: Bilstein 24-158848 Steering Damper for Ford F250/F350 4WD: Automotive
Nah, I believe you. I'm sure it will work. And the mighty Amazon can have it to me in two days. I'd like to have all new shocks before RRE. Thanks for the reply.
OK, the Bilstein came in and as I was getting ready to install I noticed this thing is pressurized like their regular shock. Seems to me this would constantly be pushing the steering to the driver's side. Holding off on the install until I figure this out. I thought their stabilizer was suppose to be neutral hydraulic.
I've always had good luck with Bilstein and wanted all to match. I'm weird like that. This is missing the washer and nut for the stud side and there's no boot. Normally I don't run boots but as low as this thing is I don't want the shaft getting chipped. Not worried about filling the boot with water too much either.
I get the everything matching disease. I'm the same way with some things too. Never ran a boot on a steering stabilizer. They usually get whacked and need replacing before the shaft wears any. If you want a boot maybe check out summit or fleabay for a universal boot that will work.
Don't know if tech compensated on alignment or not but tires are wearing normal with no additional heat on any side of the tires. (don't know if I explained that right). But I think you will know what Iam talking about.
Anyway, glad it worked for you... To me it was night and day ( smoother) than the Rancho.
Forgot to ask Did you get the 5100 series?
So did you have pull to the left before the stabilizer install or after? Was it an alignment issue or the stabilizer pushing it? Hard to believe this cylinder could do that but an old school yellow Bilstein did on my old '81 Toyota back in the day.
We leave at 'o dark 30 for RRE so if it starts pulling I'll swap the stocker back on at a rest stop.
When I went in for the alignment I did mention this to the tech. After alignment all was good.
