Smitty's Super S oils
What do you plan on using them in?
If you're planning on using the ATF in a Torqueshift, DON'T. You need Mercon SP or LV. I've also heard that Valvoline MaxLife is SP rated, but I wouldn't even bet on that.
If you're planning on using the 75W90 in the rear differential, and you have a F-250, or an F-350 SRW, DON'T. Those are a Sterling/Visteon 10.5 differential that requires 75W-140 synthetic.
The ATF will work find in a 4R100, since the 4r100 will work with about any Mercon V compatible oil. As will the gear oil be fine in the front differential.
You are taking a risk with your rear differential by using far too light of an oil. It calls for 75W-140 synthetic. But, it's your truck, you get to fix it if it breaks.
75Three90
01-16-2016 05:21 AM
JoeVR5
1983 - 2012 Ranger & B-Series
08-08-2011 10:45 AM
