AOD Wont Shift Into Overdrive
Old 07-18-2011, 09:27 PM
blake in spokane's Avatar
blake in spokane
blake in spokane is offline
93, 4x4, Wont shift into OD. I was told to ckeck the TV cable 1st. then a stuck 3-4 shift valve. If the 3-4 valve is next to check - Do I have to remove the valve body? What do I look for? How many check *****, springs, pins, are going to drop down one me? Any advise & a picture will be very apreciated.
Old 07-19-2011, 10:00 AM
RIKIL's Avatar
RIKIL
RIKIL is offline
does the OD light go on and the tranny doesn't shift into OD or does the OD light not go on at all?
Old 07-19-2011, 11:15 AM
blake in spokane
I haven't seen the light.
Old 07-19-2011, 12:50 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
‪Ford AOD TV cable adjustment‬‏ - YouTube
Here is how to adjust the TV cable.
Could also be a sticking governor but check the cable adjustment first.
Old 07-19-2011, 03:14 PM
Archion's Avatar
Archion
Archion is offline
If it is an AOD, than there will be no light as it is mechanical. If it has a button on the shifter, it is and AODE or and E4OD, and it is electronic.
Bringthepayne18
24
08-17-2017 06:18 PM
Sara_gael
05-15-2017 11:10 PM
misterbond
05-15-2017 09:30 AM
yomo50
09-28-2016 05:10 PM
david1993
04-20-2011 07:54 PM
Quick Reply: AOD Wont Shift Into Overdrive
