AOD Wont Shift Into Overdrive
93, 4x4, Wont shift into OD. I was told to ckeck the TV cable 1st. then a stuck 3-4 shift valve. If the 3-4 valve is next to check - Do I have to remove the valve body? What do I look for? How many check *****, springs, pins, are going to drop down one me? Any advise & a picture will be very apreciated.
‪Ford AOD TV cable adjustment‬‏ - YouTube
Here is how to adjust the TV cable.
Could also be a sticking governor but check the cable adjustment first.
misterbond
05-15-2017 09:30 AM
yomo50
09-28-2016 05:10 PM
david1993
04-20-2011 07:54 PM
