AOD Wont Shift Into Overdrive - Ford Truck Enthusiasts Forums
Old 07-18-2011, 09:27 PM
blake in spokane blake in spokane is offline
blake in spokane is starting off with a positive reputation.
93, 4x4, Wont shift into OD. I was told to ckeck the TV cable 1st. then a stuck 3-4 shift valve. If the 3-4 valve is next to check - Do I have to remove the valve body? What do I look for? How many check *****, springs, pins, are going to drop down one me? Any advise & a picture will be very apreciated.
Old 07-19-2011, 10:00 AM
RIKIL's Avatar
RIKIL RIKIL is offline
RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.
does the OD light go on and the tranny doesn't shift into OD or does the OD light not go on at all?
Old 07-19-2011, 11:15 AM
I haven't seen the light.
Old 07-19-2011, 12:50 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
‪Ford AOD TV cable adjustment‬‏ - YouTube
Here is how to adjust the TV cable.
Could also be a sticking governor but check the cable adjustment first.
Old 07-19-2011, 03:14 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
If it is an AOD, than there will be no light as it is mechanical. If it has a button on the shifter, it is and AODE or and E4OD, and it is electronic.
No overdrive Bringthepayne18 1999 - 2003 7.3L Power Stroke Diesel 12 11-23-2016 07:39 AM
r4100 downshifts when going from 2nd to 3rd yomo50 Clutch, Transmission, Differential, Axle & Transfer Case 8 09-28-2016 05:10 PM
E4OD TROUBLE!!!!!! "Plz Help" Grant Fralick 1997 - 2003 F150 5 05-17-2015 11:49 AM
e4od interchanges tech 101 1987 - 1996 F150 & Larger F-Series Trucks 0 09-02-2014 09:46 AM
A4LD no reverse????? cfltitans Clutch, Transmission, Differential, Axle & Transfer Case 1 01-23-2006 06:32 AM
Tags
01, 02, 2004, 87, 91, explorer, f150, f250, ford, hard, overdrive, ranger, shift, shifting, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
