how to use my dvd player in my nav while in drive - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-19-2014, 02:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
  • Safety Features
    Important information to help you understand your Ford truck
Browse all: Brake Guides
Print Wikipost
Old 07-18-2011, 09:23 PM
dennd dennd is offline
dennd is starting off with a positive reputation.
Thumbs up how to use my dvd player in my nav while in drive
Hello There,
I have a 2011 F350 Super Duty Diesel with navigation. The dvd only plays in park for safety reasons. I want to be able to watch dvd's in drive while in line ups like to the border etc.. I was told it is only cut one wire or something very simple. Can someone tell me how to do this. Maybe you know of a you tube video or can explain it simply. I am a mechanic so it will not be a problem.
Old 07-18-2011, 09:42 PM
ebexp94 ebexp94 is offline
ebexp94 is starting off with a positive reputation.
I have heard in the past that if your ground the parking brake, it will allow you to pull this off. Hoever, this is only for aftermarket units, I doubt the factory unit reads the status of the parking brake, probably the transmission.
http://www.coastaletech.com/synclockpick.htm
I googled and found this. It's far from cheap, but may be the only option for such a new vehicle with such complex technology.
I am a software engineer with one of Microsofts partner companies, and while I personally have never had anything to do with Sync, I highly doubt you will be able to mechanically overcome this systems safety/security features.
Old 07-18-2011, 09:44 PM
Excuse the spelling in my above post. I am on my cell phone. (mobile version of FTE has no Edit feature!)
Also, I'm not trying to shoot you down or anything, just giving my opinion.
Old 07-19-2011, 12:54 AM
awq134's Avatar
awq134 awq134 is offline
awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.
do you have a column shifter? if so, i would look in the column and see if there is a simple switch that when the lever is in the park it grounds out the citcuit that allows the dvd to operate. as said above, the after market one require you by law to wire it to the parking brake, however if you put on a grounded toggle switch you can flip the switch and watch to your heats content. i would advise against it tho, unless it's for the passengers only. just my .02 cents
Old 07-19-2011, 07:16 AM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
The Clarion HU/NAV uses the GPS signal to determine if the vehicle is in motion. Hard wiring a switch or ground will not work.
If you decide to install the lockpick, please make sure 1) it's not illegal in your state/county/city and 2) it is ONLY used for passengers.
Old 07-19-2011, 12:12 PM
my dvd in my navigation
Hello Again,
Thanks for the reply. I have found out how to do it. It is a five minute or less job. It is a simple cut of a wire under the dash. It will be for me to watch in drive....but only for when I am in a line up or waiting for a train, border etc. Trust me, I am a very saftey type guy and I will not be using the dvd while going doen the road.
Thanks Again
Old 07-19-2011, 12:27 PM
shotgunz's Avatar
I'd love to know the source of this information 'cause I'm pretty sure he/she is wrong and you're going to end up with a non-functioning Nav unit.
A Clarion employee used to frequent the Audio Forum and he was pretty adamant that you cannot simply cut wire(s) to bypass the safety feature.
Then again, I've been wrong before and if you're right you could save a lot of people a lot of money (vs. buying the lockpick).
Old 07-19-2011, 12:59 PM
Pale Screw's Avatar
Pale Screw Pale Screw is offline
Pale Screw is starting off with a positive reputation.
He might be referring to the speed sense wire. This could affect how the Nav system works, or render it useless. This may also affect the operation of the cruise control. You never know now a days with all the electronics. A lot of systems, and sub-systems share wiring / components to function properly. I would use extreme caution when modifying, or hacking into the factory harness for anything.
Old 07-19-2011, 01:16 PM
shotgunz's Avatar
Could be, but the current Nav/HU doesn't use the speed sense wire - it used the GPS signal.
See post No. 6: http://www.ford-trucks.com/forums/91...unit-help.html
Old 12-13-2011, 01:46 AM
gomerpyell gomerpyell is offline
gomerpyell is starting off with a positive reputation.
wat wire did you cut and where and did it work for you
Old 12-13-2011, 05:14 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Moved to correct forum!
Old 12-13-2011, 08:49 PM
bigal614's Avatar
bigal614 bigal614 is offline
bigal614 is starting off with a positive reputation.
FORD LOCKPICKS
I bought this unit and have to say that it's well worth the money.
How much did your truck cost and your worrying about a couple hundred bucks for something that works and won't mess your vehicle up?
Old 12-14-2011, 06:32 AM
shotgunz's Avatar
Quote:
Originally Posted by bigal614 View Post
FORD LOCKPICKS How much did your truck cost and your worrying about a couple hundred bucks for something that works and won't mess your vehicle up?
And how much are you out when it does?
Old 09-29-2013, 07:20 PM
J Bossman J Bossman is offline
J Bossman is starting off with a positive reputation.
Quote:
Originally Posted by dennd View Post
Hello There,
Did u find out how to bypass the DVD while driving is so can u tell me
Old 09-30-2013, 12:02 PM
MX727's Avatar
MX727 MX727 is offline
MX727 is starting off with a positive reputation.
You have to remove the GPS signal to the head unit and fool the unit into thinking that the parking brake is set. I'm sure you can find the GPS wire and put a switch on it. At that point, you may be able to set one click on the parking brake and have it work. However, the Lockpick is a cleaner, reversible, albeit, more expensive solution. The Lockpick will also allow you to add additional cameras and you can use your cameras while in motion.
can movies on a phone be watched via dvd auxiliary jacks? norman2012 Excursion - King of SUVs 13 06-25-2016 06:31 PM
Sony Nav - No DVD David1986 2009 - 2014 F150 1 08-19-2014 08:57 PM
Can I Add Monitors To My Nav System? ZEALOUS_DRAGON Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 12-07-2011 12:02 AM
2010 F250 with sync nav and DVD player Jake_2010_F250 1999 to 2016 Super Duty 4 06-20-2010 12:38 AM
06 Expedition DVD issue 06 Expy Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 02-28-2010 12:11 PM
Tags
2010, 2011, bypass, car, drive, dvd, f150, ford, make, navigation, play, player, safety, switch, toggle, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
