Cracked Tow Mirror
Cracked Tow Mirror
Hey, I have cracked the Orange signal cover on a 2011 Super Duty Tow Mirror, Does anyone know if that one part can be replaced in an inexpencive mannor, or if the whole back caseing has to be replaced,
Also- Is it possible just to pop that one plastic part off? I beleive the signal bulb is loose in the casing, and I dont want to break it taking it off,
If there is a DIY thread please post it, thanks
Recon carries aftermarket lenses, Ford Superduty Side Mirror Lenses for all Ford Superduty Truck F250 F350 F450 F550 2003-2012
Looks like Ed can get them for you pretty reasonable though, http://www.trademotion.com/partlocat...layCatalogid=0
Sorry I do not know, I was just trying to help locate parts for you, I would assume it either pops in place or has a retaining screw somewhere. Try moving the glass as far in as you can to see if there is a screw behind the glass. Here was some instructions for the 08 https://www.ford-trucks.com/forums/9...placement.html
hasteranger
02-14-2012 03:11 PM
majkthreads
1999 to 2016 Super Duty
19
06-01-2011 08:28 PM
