Triton blown plugs - Ford Truck Enthusiasts Forums
Triton blown plugs
Old 07-18-2011, 04:04 PM
leedall24 leedall24 is offline
leedall24 is starting off with a positive reputation.
Triton blown plugs
I have a 2002 F-150 5.4L. A few weeks ago #8 plug blew out when I started it in my driveway. I re threaded the plug and put on new coil. Truck ran great. A week later, #7 blew out. Again, the plug threaded, no problem, new coil and truck ran great. Three days later, #8 blows again. This time a new plug will not thread. After talking to some friends, and some research on You Tube, this seems to be a very common problem. So common, there are several kits available to fix this without pulling the head. I used Fix-a-Thred #98140T, about $150.00. I re tapped 7 and 8, new plug and was off smiling. The next day, #3 blew out. I have decided to park it, and re thread the remaining six. I ordered all new coils,( 8 Pack, Summit Racing #ACC-140032-8, $189.95), and all new plugs. I ordered extra thread inserts from Auto Zone #FIX98149P, about $30.00. Because the threads on the blown plugs were rusted, I chalk this one up to moisture, heat, expansion and contraction. I plan on using red thread locker on outer threads of insert, and a thread sealer on inner threads. By the way, this all started when I pressure washed my motor for the first time. Any advice would be greatly apprecieated.
Old 07-18-2011, 10:57 PM
fordtrader fordtrader is offline
fordtrader is starting off with a positive reputation.
Mac Tools has a great kit that uses a new thread insert, not just helicoils, we use it @ the shop I run, never had a problem, helicoils can come out again.
Old 07-19-2011, 03:42 PM
The kit I mentioned are also steel inserts, not helicoils. I just finished about 30 min ago tapping the remaining six, and threading in new inserts and plugs. Just waiting on a new set of coils from Accel. And again, all the threads on the plugs were rusted bad. Hmmm.....
Old 07-20-2011, 11:18 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Use those ^ if you want to fix the problem.
Sounds like the vehicle was not maintained properly and neglected. The rusted threads on the plugs that blew was more than likely there because they were loose and backing out for a while before they blew. There was probably warning signs (exhaust leak noise) warning the plugs were backed out. Probably all started because the last person or the person before them screwed up a smile plug change.
Re-thread blew out wanderer575 Modular V10 (6.8l) 4 03-10-2016 08:01 AM
Blown Plug on #10 cylinder - Best fixes? icentropy Modular V10 (6.8l) 12 03-19-2014 12:08 PM
Another successful plug story... LACityFD 2004 - 2008 F150 0 11-20-2011 03:28 PM
98 4.6 misfire after blown spark plug fix jadwin 1997 - 2003 F150 4 02-09-2010 08:20 PM
#8 cylinder misfire, can't figure it out. natethegreat_2005 1997 - 2003 F150 13 04-18-2008 12:52 AM
Tags
2002, 98140t, back, blown, f150, fix98149p, fixathred, ford, intake, plug, plugs, put, sealant, thread, triton, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
