V10 Stalling and Auto Enginuity
RCM = Restraint Control Module?
This would cause a no start? I guess logically it would.
Questions:
a: Certain it's the RCM?
b: Where is it located?
I guess with my AE I should be able to see this sensor. Soon as the laptop is charged up again, I'll go back at it.
Where did you find the meaning of this code?
All I see is ECU is Faulted overhead console
Questions:
My autozone uses Actron. I've diagnosed a million things with theirs. The AE I just bought. Here's the big difference.
With the Autozone one I showed a OSS code. I replaced the Output Speed Sensor. Didn't solve the problems.
With AE I could see individual cylinders and if there were misfired. I had an issue with Cylinder #6. I replaced the COP and it appears problem solved.
It wasn't misfiring enough to cause a code to trip, just enough to make the truck run rough and stall in intersections. Blue Oval wisdom I guess.
So for me, the AE was worth the 392.60 I spent on it. Been working on my 05 6.0L for the last day and a half on a no start. I've check alot of things I wouldn't have been able to at Autozone.
Just my .02....
Just my .02....
Just my .02....
Just my .02....
Still running good? I am about to pull the trigger on AE to find my 02 miss
hambass
11-23-2022 08:02 PM
Shalapua52
08-02-2017 06:56 AM
