Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 07-18-2011, 12:35 PM
brcrk's Avatar
brcrk brcrk is offline
1991 Ford F-150
brcrk is starting off with a positive reputation.
What to look for when buying used Lightning
I am looking to buy a 2nd generation Lightning. Since I have never dealt with these trucks I thought I would ask yall for your input on the truck. Is there anything particular (besides the obvious when buying a "regular" used truck) thing to look for before making this purchase.
__________________
Tim Taylor
91' F150 4x4 "Nite" Special Edition
351w, 5 Speed, 5" Lift, 35x12.50 BFG
  #2 (permalink)
Old 07-18-2011, 01:53 PM
phil6608's Avatar
phil6608 phil6608 is offline
Garage is empty, add now
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
99 to I think 01 had a leaky intercooler,
Find out if the recall was performed if looking for one of that year.
They all suck oil into the intercooler if ran without an oil separator.
If theres no oil separator, ask when the last time the intercooler was cleaned. And expect to do that if it hasn't been done lately or if it doesn't have an oil separator.
Also see if its been running at a higher boost level then stock.(aftermarket pulleys)
The higher the boost level,the faster the motor will where out!
Look for a nitrous port(there would be a little plug in the intake system if he ran nitrous on it)
Good luck,
naturally,the lower the miles the better.
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
  #3 (permalink)
Old 07-23-2011, 04:35 PM
Lightning Rod's Avatar
Lightning Rod Lightning Rod is offline
Lightning Rod is starting off with a positive reputation.
Check the rear driveshaft link to see if the u-joints and pinion yolk look like they've been beaten with a hammer. Lightnings that have been run with slicks and no traction control devices will show damage in this area.
'99s required the intercooler upgrade, so make sure the recall was honored. Also make sure the cruise control switch was replaced under recall... I think this was for all Lightnings.
__________________
Ken Wilson
HALO Vice President
"Anything less than a Lightning becomes prey"
403 RWHP / 518 RWTQ
  #4 (permalink)
Old 07-24-2011, 02:40 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
It wasn't a recall. The intercoolers were replaced under a customer satisfaction program.
Those things leaked like a sieve, so it's a pretty safe bet it's already been replaced, either by Ford or the owner.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #5 (permalink)
Old 07-24-2011, 02:47 AM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Quote:
'99-'02 model year had the heads with 4 threads per spark plug holes. This causes a situation where the spark plugs are easily launched from the heads.
This problem is not limited to the Lightnings, as all the modular engines Ford made have this problem.
Starting with the '03 model year, Ford started using heads with more threads in the spark plug holes.
The '99 and '00 model year L's produced 360hp and 440 ft. lbs of torque and had 3.55 gears in the diff.
Starting in '01, due to slight changes by Ford (80mm MAF to a 90mm MAF and some other tweeking), the L's produced 380hp and 450 ft. lbs of torque and were now sporting 3.73 gears in the diff.
Ford also stopped using the 3.5" steel driveshaft and started putting a 4.5" aluminum driveshaft in the L's in '01.
All of the Gen 2 L's have the 4R100 tranny. A very stout unit used by Ford for the 7.3L PSD's.
Look for obvious stuff. Has it been modified and how extensively? If it has been modified, were there any custom tunes put on the truck? If so, how? Chip or flash and who wrote the tune? Someone reputable?
I'd also check how many owners the L has had. Are you buying from a younger adult or an older adult?
One thing I do is look at the engine bay. You can USUALLY ascertain if the present owner has kept the bay clean, or if its just been recently cleaned because it's for sale.
I look for this because, even though its very subjective, usually if the owner is meticulous enough to keep the engine bay clean all the time, then he has an eye for detail and will usually treat/work on/modifiy and generally take better care of the truck than someone who doesn't clean the engine bay.
Again, that's not a hard and fast rule, but I've found it to be true more times than not.
Stewart
__________________
Tags
2nd, 4x4, buying, f150, ford, gen, harley, lightning, nova, recalls, taylor, tim, truck, watch, whattolookforwhenbuyingusedlightning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
