Steering wheel, transmission questions
Just about any of the major suppliers have those tailight and front turn signal assemblies, bulbs, etc. Classic Haulers up in Indiana (speak to Candi), Early Ford, Dennis Carpenter to name a few. I'm assuming you're talking about a truck that is still 6 volt. If that's the case, you can buy the bulbs at most parts houses if that's all you need. You'll need an 1154 bulb for 6 volt (or the old standby 1157 if your truck has been converted to 12 volt). But if you're needing the whole thing, I'd recc. you just call one of those places and get the right tailight assemblies with brackets instead of trying to re-invent the wheel with a universal kit off the shelf.
We need to see pictures of your truck!!!
Actually it has been converted to 12 volts. I have stoplights/taillights which I assume work. But there isn't the extra wire needed for the turn signals.
I have looked and looked and vendors online and not seen the bulb or anything to convert taillights/stoplights to turn signals.
I assume another wire has to be added somehow, right??
Thanks.
Thanks.
It's much more than just adding a wire. Do you have a turn signal installed right now? If so, you need to give us a picture or at least a brand name.
If your truck never had a turn signal to begin with, you might want to consider something like the "Signal Stat 900". That one seems to be the most popular as an aftermarket install. There are some good threads about it here on FTE along with the wiring diagram. You'll end up running an extra wire to every signal light, changing all your bulbs to double filament (and changing out the contacts inside the lights too if it only had single filament bulbs), and you'll have to add a blinker under the dash among other things. The switch itself will come pre-wired. You'll need to purchase the other stuff separately.
Thanks.
Thanks.
(I think this is my 1000th post and I haven't really said a damn thing worthwhile since I joined )
Yes. And I think it's really cool to see how the switch will blink one side and still activate the brake light on the other side. But, to eliminate confusion, you still need the double filament bulb because the running lights are on a separate circuit altogether.
Just a note tho, you need to replace the entire socket if converting from single to dual filaments. The pins on the 2-filament bulbs are offset so the bulb can only go in one way. Replacing the socket can be easy or impossible, depending on the condition of the light's base inside.
Oh, go on Doc!! Congrats!
I don't know what dual-filament bulb would have "even" pins; I checked the Sylvania catalog and don't see any without an "indexed base" (offset pins). Do you know the number for the even pins?
#30
