48-50 F5.5 I'll strip what I can
Old 07-20-2011, 10:16 AM
dmptrkr's Avatar
dmptrkr
dmptrkr is offline
If the truck has a two speed axle the vacuum shift operator can be golden to someone cause they are not repopped or serviceable. You can tell if they might be any good by sucking on the vacuum port to see if the diaphragm leaks. Best to use a mighty vac pump.
The fire wall mounted vacuum shift valve, vacuum booster check valve, hard piping, and two speed axle speedometer adapter are all hard to replace or repair big truck parts and easy to ship. If the truck has a brake booster it is usually worthless but the breather assembly that pokes up into the cab and the five way brass hydraulic manifold at the back of the master cylinder might be worth a few bucks and easy to ship.
Old 07-20-2011, 11:11 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
I second what dmptrkr said as I've sold those pieces in the past when I parted out an F5 and an F6.
Old 04-18-2012, 09:05 PM
cstempert's Avatar
cstempert
cstempert is offline
Are the front drums still around?
Old 04-19-2012, 09:43 AM
52 M1 Kootenay Kid's Avatar
52 M1 Kootenay Kid
52 M1 Kootenay Kid is offline
Crushed and hauled out.
Old 04-19-2012, 09:46 AM
cstempert's Avatar
cstempert
Figured, but had to ask...
Keep your eyes peeled for more, that's all
C
tjdad62
10-12-2014 11:10 PM
luckyguy1316
12-31-2013 03:34 PM
scatgo
11-20-2011 10:58 PM
cornking
01-05-2010 06:01 PM
imlowr2
22
08-30-2005 10:03 AM
Quick Reply: 48-50 F5.5 I'll strip what I can
