New F150 owner
New F150 owner
Hi all,
Brand spanking new member here. Also a proud owner of a 1995 4x4 f150 XLT, auto (3speed with OD) with 184,000 miles. I've been driving a '91 2x4 f150 lariat as a work truck and have been loving it, so I bought this one to take my family camping with a trailer.
As I was driving it on the freeway, I started noticing some vibrations (hubs are in the "free" position) I was going about 70mph. They went away on inclines, and when I took my foot off the gas pedal. When I did that, though, I noticed a "clunk" sound. Is there something wrong with my transmission? I also feel a clunk when I shift from R to 1st.
Thank you very much.
Ok, first off, don't bother "checking" your speed sensor. It has nothing to do with the problem.
The clunk is probably your u-joints. Jack up the rear axle and support it with jackstands. Crawl under it and check all the u-joints in the driveline for free play. They should all be tight. If there is movement in any of them, replace them.
Trans yokes will bind then 'clunk' when the pressure is released. Had this happen when all the usual checks in the driveline were checked and dbl checked. Under load, the yoke (splined) is under pressure and held in place. when the pressure is removed, it slides to the 'new' position.
Hope this makes sense.
thanks, everybody. i crawled under the truck, and sure enough, with it in N, the rear drive shaft u-joints had tons of play in them. i got some new ones, made by precision.
i've been on youtube, and it seems like there are millions of methods to remove and replace these puppies, using hammers, bench vises, u-joint presses, extractors and installers. i'm thinking i'm going to try to rent a u-joint press and not use the hammer or bench vise methods. i hope this tool will allow me to install the u joints straight, without loosing any needles. do you have any suggestions?
thanks!
thanks!
