Axle ID
Old 07-17-2011, 05:23 PM
Josh B's Avatar
Josh B
Josh B is offline
Axle ID
I have a question on my 64 Ford I just picked up, the numbers on the rear axle are 02AW-4668 A and 4E20 58 What do these mean? Thats the best I could tell wht they were after scarping years of dirt and grime off the 3rd member. No drain plugs in it as i could see either. And also on the ID tag on the drivers side door the axle code or number says.......Axle 12 what does this mean to any help would be appreciated thanks.
Josh
Old 07-17-2011, 05:57 PM
ilmo's Avatar
ilmo
ilmo is offline
You could probably get more information in the 1961-1966 F100 forum, but here is something that may help.
What is my Ford rear end ratio, do I have positraction? - Drivetrain.com
Old 07-17-2011, 06:12 PM
Josh B's Avatar
Josh B
Josh B is offline
Thank you.
Old 07-17-2011, 08:19 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Welcome. Moved to the correct forum.
Old 07-18-2011, 08:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Josh B
I have a question on my 64 Ford I just picked up, the numbers on the rear axle are C2AW-4668 A and 4E20 58 What do these mean?
And also on the Warranty Plate on the drivers side door, the Axle code is 12 what does this mean?
Welcome to FTE
C2AW-4668-A = ID number found on the carrier. Ford part number: C2AZ-4141-B.
4E20 = Rear axle assembled May (E) 20, 1964 (4).
58 = Assembly plant code.
12: Ford 9" Rear Axle / 3.89-1 / non Limited Slip / 3,300 lb, Rear Axle Capacity.
Old 07-18-2011, 08:07 PM
Josh B's Avatar
Josh B
Josh B is offline
Thank you very much for the help!! Thats great info to know.
Josh
coreylasalle
143
12-10-2021 11:08 PM
64M100builder
08-07-2016 11:02 AM
Boss300
16
01-29-2016 09:34 AM
coreylasalle
85
01-28-2016 04:11 AM
wyazel1
27
07-07-2012 07:19 PM
Quick Reply: Axle ID
