Arkansas Chapter Join Chapter Leader: Kramercd
Need Someone Who knows Carbs Around Cabot
Old 07-17-2011, 04:34 PM
jjski78's Avatar
jjski78
jjski78 is offline
Any Arkansas members local to Cabot that could possibly show me how to set up my carb? I replaced it with a Holley rebuild and ever since I have to pour fuel down the throat for the first start of the day and it idles STUPID fast. I'm a bit on the dumb side when it comes to carbs, and could really use some help with someone showing me what to do. Any takers?? A 12 pack of your favorite brew would most definitely be involved.
Old 07-18-2011, 05:05 PM
cookie88's Avatar
cookie88
cookie88 is offline
this a 2 barrel on the straight six in your sig?
Old 07-18-2011, 07:09 PM
jjski78's Avatar
jjski78
jjski78 is offline
Nope, it's got the single 1 barrel Carter on it.
Old 07-18-2011, 09:47 PM
tojoski's Avatar
tojoski
tojoski is offline
I've never adjusted one of the 1bl, but I've done plenty of the 2bl holleys.
Idle adjustment is easy, as for the mixture I've always had to go back to the book.
Havin to prime it every time seems almost like a fuel pump problem..there should be enough in the fuel bowl to get it started, just thinkin out loud.
I'm sure if we put a few heads together we could figure it out..
Old 07-19-2011, 10:10 AM
mudder460's Avatar
mudder460
mudder460 is offline
Those 1bbl carbs are a pain to get set up right. I think I have mine almost tuned in. I can take a look but I'm no expert about it.
Old 07-24-2011, 10:04 AM
jjski78's Avatar
jjski78
jjski78 is offline
Well I got it worked out. The carb base gasket was junk. Replaced that, tuned the mixture screw until I was pulling a constant 25"Hg, and set the idle to not screaming. Don't have a tach so I set it by ear. Now the only problem I have is when I use my AC the truck stalls when I come to a stop. I think the compressor is going bad on it and causing too much drag at idle. So I guess I'll just switch off the AC whenever I come to a stop until I can afford the Sanden compressor swap kit.
Mudder...are you the red 4x4 that's always parked outside the back gate??? If so your truck is beautiful.
Old 07-24-2011, 08:37 PM
mudder460's Avatar
mudder460
No, thats not me. My truck is pretty ugly right now. I know the one you are talking about though.
Old 08-18-2011, 08:06 PM
cookie88's Avatar
cookie88
cookie88 is offline
That is a dang fine looking truck parked back there
Jeremy W
New Member Introductions
01-08-2014 07:42 PM
TheWhiteBeast
Arkansas Chapter
02-05-2012 03:54 PM
arkredneck
Arkansas Chapter
07-16-2009 04:45 PM
tipthewaiter
84
07-01-2008 05:45 PM
cookie88
Arkansas Chapter
26
08-27-2007 10:18 PM
Quick Reply: Need Someone Who knows Carbs Around Cabot
