Sinister Coolant Filter Install HELP!!!
I am currently flushing my coolant system with VC-9, and I just installed my fumoto valves in the block drains. I would also like to install the coolant filter set up that came in earler this week. While looking at the set up with my system running I am unsure which side of the heater control valve to install the bypass hose on. The instructions make no mention of it, and the help line is only up monday-friday. I would realy like to install it today. If anybody out there has ran into this before I could use the advice!
I wish I still had my instructions I put in in like this:
I read the instructions a couple of times and thought I was clear on it but the more I think about it,,, If the valve stops coolant flow FROM the engine then what I have done is flowing coolant throught the heater core all the time?! If the valve stops coolant flow TO the engine from the heater core then...I am still flowing coolant through it all the time.
Hmm......A/C is still cooling very well even with the temps we've been having and lines to filter get hot.
I'm thinkin I smooched the pooch on this one?
