93 ranger oil pressure fluxuation
Old 07-17-2011, 01:12 PM
ditch witch's Avatar
ditch witch
ditch witch is offline
Truck has 48,000 miles. When ever not running has been in garage.
Oil pressure gauge reads between the M and A in NORMAL on the gauge. When RPM drop down to about 1200 gauge flutters and falls down. When at a complete stop gauge drops outside of the low mark.
This does not happen all the time, just randomly. I replaced the sending unit. Same results. Engine never sounds like low oil pressure. Runs as good as a 3.0 can-----.
Is there a location other then the oil sending unit to tap in for a mechanical guage?
The brake and ABS light comes on randomly also. Maybe it has ghost!!!
Old 07-17-2011, 06:07 PM
Phinxter's Avatar
Phinxter
Phinxter is offline
Got the same problem sort of, after a long hwy drive and I come to a stop the gauge flutters, I guess this thing is no sender but just a switch and the guage is a fake lol. you might check around the oil filter, many times there is a plug there someplace.
Old 07-17-2011, 07:37 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
Yup ford has wired our op gauge so that it's nothing more than a mechanical idiot light!!!!
When the op gauge reads low, does the op warning light turn on???
If you've replaced the op sender, then check it's electrical connector for loose fit, or corrosion & it's wiring for broken strands.
If thats ok, did you use PTFE ribbon dope on the threads for a sealant???? If so, it may not be making a good ground connection through the threads to the engine block. so maybe check it with an ohm meter, or connect a ground wire from the chassis to the sensors metal casing & see if it stops acting out.
Let us know what you find.
Old 07-17-2011, 08:59 PM
ditch witch
Thanks for the replies. On the 3.0 you have to be a long armed contortionist monkey to change the sending unit! I found the easiest method was to remove the pass. tire and reach up from there.
The op warning light does not come on.
The electrical connection was in interference fit, and quite clean. I don't think that is a problem.
So now you're suggesting I got to get back in there to make sure the ground it good? I wondered why that came without any sealant on the threads.
I did wrap some teflon tape on the threads.
Rocketattack
04-25-2016 09:00 PM
Leroy Unlisted
04-05-2016 07:32 AM
insane96
02-15-2013 10:07 PM
n4ynu1010
17
08-04-2012 09:05 AM
CharlesNeff
07-17-2007 06:51 AM
Quick Reply: 93 ranger oil pressure fluxuation
