93 ranger oil pressure fluxuation - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-17-2011, 01:12 PM
ditch witch ditch witch is offline
ditch witch is starting off with a positive reputation.
Truck has 48,000 miles. When ever not running has been in garage.
Oil pressure gauge reads between the M and A in NORMAL on the gauge. When RPM drop down to about 1200 gauge flutters and falls down. When at a complete stop gauge drops outside of the low mark.
This does not happen all the time, just randomly. I replaced the sending unit. Same results. Engine never sounds like low oil pressure. Runs as good as a 3.0 can-----.
Is there a location other then the oil sending unit to tap in for a mechanical guage?
The brake and ABS light comes on randomly also. Maybe it has ghost!!!
Old 07-17-2011, 06:07 PM
Phinxter's Avatar
Phinxter Phinxter is offline
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
Got the same problem sort of, after a long hwy drive and I come to a stop the gauge flutters, I guess this thing is no sender but just a switch and the guage is a fake lol. you might check around the oil filter, many times there is a plug there someplace.
Old 07-17-2011, 07:37 PM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Yup ford has wired our op gauge so that it's nothing more than a mechanical idiot light!!!!
When the op gauge reads low, does the op warning light turn on???
If you've replaced the op sender, then check it's electrical connector for loose fit, or corrosion & it's wiring for broken strands.
If thats ok, did you use PTFE ribbon dope on the threads for a sealant???? If so, it may not be making a good ground connection through the threads to the engine block. so maybe check it with an ohm meter, or connect a ground wire from the chassis to the sensors metal casing & see if it stops acting out.
Let us know what you find.
Old 07-17-2011, 08:59 PM
Thanks for the replies. On the 3.0 you have to be a long armed contortionist monkey to change the sending unit! I found the easiest method was to remove the pass. tire and reach up from there.
The op warning light does not come on.
The electrical connection was in interference fit, and quite clean. I don't think that is a problem.
So now you're suggesting I got to get back in there to make sure the ground it good? I wondered why that came without any sealant on the threads.
I did wrap some teflon tape on the threads.
1996 F350 7.3 died coming to a stop. Lance Empey 1999 to 2016 Super Duty 0 06-09-2015 12:43 AM
7.3 oil pressure problem gerald broussard 1999 - 2003 7.3L Power Stroke Diesel 5 03-06-2014 08:02 PM
Bad ECM ? n4ynu1010 1987 - 1996 F150 & Larger F-Series Trucks 17 08-04-2012 09:05 AM
2.9 oil sending unit location tmryan362 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 3 03-25-2004 06:29 PM
Oil Pressure gauge or sending unit? Dog_Brains Ford Inline Six, 200, 250, 4.9L / 300 5 06-28-2001 11:37 PM
Tags
1986, 1992, 1993, 93, 97, engine, ford, gauge, high, low, oil, pressure, ranger, recall, sending, sensor, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
