FICM grounding?? - Ford Truck Enthusiasts Forums
FICM grounding??
Old 07-17-2011, 08:50 AM
john11139 john11139 is offline
john11139 is starting off with a positive reputation.
FICM grounding??
Is there a external ground wire from firewall to FICM case? Removed engine, seems like there was a ground wire on left firewall that went somewhere. Cant fined it. One on right side behing head is connected.
Old 07-17-2011, 10:04 AM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
no ground on the left side. just on the back of the right head to above the evap case.
Through the wall Methodic Menace 1968-2013 Full Size Vans 2 02-29-2016 09:26 AM
GROUND STRAP HOT FRANKLIN0716 Excursion - King of SUVs 10 01-15-2016 12:43 PM
small stud on ficm bracket troy676 6.0L Power Stroke Diesel 5 07-19-2015 08:38 AM
FICM & GROUND WIRE jerkypants 6.0L Power Stroke Diesel 5 05-28-2014 08:20 PM
FICM Ground wire goes no where... jeepsterjc 6.0L Power Stroke Diesel 5 05-28-2014 08:17 PM
Tags
0, 2003, 2006, 60, back, diesel, f250, f350, ficm, ford, ground, location, motor, powerstroke, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
